07-30-2018, 10:40 PM | #1 |
Cupola questions
I noticed little droplets of water working it’s way up between the threads and the nut of the head bolt adjacent to the distributor on the drivers side. Does this indicate a blown head gasket?
Also, where would I look for the cause of backfiring when the engine is turned off. What is the cause of the gas leakage around the carb in the photo? |
07-30-2018, 11:05 PM | #2 |
Re: Cupola questions
"...backfiring when the engine is turned off" is almost always timing when I did my first tune-up I could shut off the car and get out before it sounding like a rifle went off.
It is never good to see that on a head as it indicates a crack. If it were my car and it being driving season in most parts of the country, I would either leave it and monitor it until the winter when the head can be removed for inspection, or remove the nut and put a little permatex sealer around the bolt and tighten it again and monitor it until the winter when the head can be removed for inspection.
07-30-2018, 11:14 PM | #3 |
It looks like more than just a head nut leaking.
07-31-2018, 10:41 AM | #4 |
The gas leaking, could just be bad gasket and sloshing allowing it to leak out or float level is set too high.
07-31-2018, 11:34 AM | #5 |
A jar of BARS-LEAKS & if it looks OK, just drive on.
Bill Nottooexcited
07-31-2018, 09:25 PM | #6 |
08-01-2018, 09:49 AM | #7 |
see #2
08-02-2018, 09:28 AM | #8 |
I was expecting questions on this....
08-02-2018, 03:54 PM | #9 |
Looks like the one they built, on "This Old House" program. Just before the TERMITE ALARM went off!!!
Bill Nailer
08-02-2018, 06:39 PM | #10 |
08-03-2018, 11:57 AM | #11 |
Is the gas wicking up from your GAV?
