Old 04-03-2020, 07:01 PM   #1
M2M
M2M's Avatar
Question Are the supplier's "v8 STYLE pressure plates" really for tractors?
I was reading this:
http://www.fordgarage.com/pages/pressureplates.htm
Do any of the suppliers currently sell real v8 pressure plates (rather than "v8 STYLE") that have flyweights, or they all sell the inferior tractor ones, as described in article above.
M2M is offline   Reply With Quote
Old 04-03-2020, 07:20 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Are the supplier's "v8 STYLE pressure plates" really for tractors?
I guess the best thing to do before buying is to ask and be sure. I think the better shops will sell the correct parts or at least be upfront about their products.
Old 04-04-2020, 11:58 AM   #3
denis4x4
denis4x4's Avatar
Having owned a Ford 9N tractor, I would have to take umbrage to the "inferior tractor ones" according to the OP. That said, Bert's has the V-8 pressure plates. My flywheel is 28 pounds.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 04-04-2020, 12:31 PM   #4
Jim Brierley
The tractor clutches don't have the weights on the fingers that V8 clutches have. They increase the clamping force at higher RPM's. I recommend diaphragm clutches, they are much smoother, clamp well and take less pedal pressure to operate them.
Old 04-04-2020, 12:46 PM   #5
hardtimes
hardtimes's Avatar
Hey Jim B,
I agree on both points that you've made here.
Centrifugal weights were/are improvement over 'tractor' PP, that's obvious advancement.
I lost my spec info as to which diaphragm PP you used (year/model number).
Can you issue that to me again please.
Old 04-04-2020, 12:51 PM   #6
M2M
M2M's Avatar
Bert's website says "v8 style pressure plates"...do these have flyweights?
Old 04-05-2020, 11:47 AM   #7
Jim Brierley
Hardtimes, mine is a #07017D bought from Clutch Masters in Rialto, CA. They machined my flywheel too, I furnished one already cut for a V8 clutch.
Old 04-05-2020, 12:17 PM   #8
PC/SR
The so called tractor style have pressure plate pivot points secured by cir clips. The V8 with the counterwiegits have the pivot points secured by cotter pins. I had a cir clip come off. Clutch would not release. Towed home. V8 pp are available at Ft Wayne Clutch, google it. The have a "kit" includes TO and pilot bearings and clutch.
PC/SR is offline   Reply With Quote
Old 04-05-2020, 12:43 PM   #9
jak
THe ones that Bratton's sells has the counterweights on it.
https://www.brattons.com/v-8-style-pressure-plate.html
jak is offline   Reply With Quote
Old 04-05-2020, 02:25 PM   #10
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
This is the PP that Brattons sells.
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 04-05-2020, 02:27 PM   #11
PC/SR
Check with Brattons first. I bought a pplate thinking it had the counterweights because of the picture, and it was the tractor type when I received it. Maybe different now.
Old 04-06-2020, 11:46 PM   #12
hardtimes
hardtimes's Avatar
THANKS Jim !
Old 04-06-2020, 11:52 PM   #13
hardtimes
hardtimes's Avatar
Problem with the disk shown, IMO /experience, is that springs are not ‘captured’
by the metal tabs. When the springs fatigue / rattle, over time, they can fall out of place and into the works.
Old 04-07-2020, 12:30 AM   #14
M2M
M2M's Avatar
Do original v8 PP have "captured" springs?
Old 04-07-2020, 09:19 AM   #15
30 Closed Cab PU
The picture seems to have flanges on the spring openings. Those do not capture the springs?
Old 04-07-2020, 02:35 PM   #16
hardtimes
hardtimes's Avatar
Not springs of PP. The disc springs.
Old 04-07-2020, 02:39 PM   #17
hardtimes
hardtimes's Avatar
Doesn’t “seem to have” , to my CVS glasses adj eyes !
Point being, there are worse and there are better disc to choose from. Your choice.
Old 04-07-2020, 09:46 PM   #18
M2M
M2M's Avatar
Bratton's seem to have the better disc.
Bratton's
https://www.brattons.com/clutch-disc.html
Snyder's
https://snydersantiqueauto.com/Produ...0_CLUTCH-DISC?
Old 04-07-2020, 09:55 PM   #19
M2M
M2M's Avatar
Thanks for the info.
Here it is:
https://fortwayneclutch.com/product/...-sku-kt5102_r/
It says the PP is "reman". The new Bratton PP looks very similar.
Old 04-08-2020, 10:48 AM   #20
Kurt in NJ
Kurt in NJ's Avatar
I have a original Ford disc (v8)in my A, it was in the car when I got it 50 years ago, I took the picture when I was trying to get it unstuck, drove over 40 miles jerking it, still wouldn't pop loose, had the car bucking jumping on- off gas, then I learned that I could shift without grinding, that the starter did fine starting from a stop in gear, I tapped the hole in the picture , put a bolt in it and yanked, and it popped off the flywheel---- the original Ford disc doesn't have spring capture flanges, and neither in the box nos ones don't have them, perhaps the springs are better, the metal thicker than modern production --- in the era it was common to replace just the facings on old disc
Yes, I drove nearly all the 40 miles with my foot on the clutch and no change in crankshaft end play
Kurt in NJ is online now   Reply With Quote
