Old 09-28-2019, 11:49 AM   #1
Beater
Beater's Avatar
Default model A/B lifters
well I know the B cam is different in lift than the A, and the lifters are wider face. but are the bores the same? looking to put an aftermarket set of adjustable lifters in my B block just trying to make sure the bore is the same for A and B
Beater is offline   Reply With Quote
Old 09-28-2019, 12:06 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: model A/B lifters
Yes it is the same.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-28-2019, 12:07 PM   #3
johnneilson
yes, they should be the same bore in the block.
I say should, 80+ years and who knows who worked on motor before.
Also be careful, adjustable lifters can come in different face diameters, some too small for the "B" cam.
Your best bet might be to measure the old ones before purchasing the new, if possible.
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 09-28-2019, 12:28 PM   #4
Pete
Pete's Avatar
The lifter bores are something few rebuilders check. Badly worn ones can make a poor running engine.
There is a remedy.
As a side note, most modern regrind cams are designed to run on 1 inch diameter lifters so you need to determine this from the cam supplier. The double lock lifters are 1 inch.
Old 09-28-2019, 01:24 PM   #5
Mulletwagon
Mulletwagon's Avatar
J
X2 Need to ensure the bores have or have not been machined for oversize lifters.
Mulletwagon is offline   Reply With Quote
Old 09-28-2019, 03:50 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I would use the model B lifters . The best that I recall the face of the B lifters , where they meet the lobe of the cam is larger than model A . The B lifters are a small amount longer but adjustable lifters could solve that problem but not face diameter .
Old 09-29-2019, 12:51 PM   #7
Beater
Beater's Avatar
thanks
