04-03-2013, 09:41 PM | #1 |
Need help with new guy mistake.
I need help getting my A back on the road.
Today I was replacing the spark plugs on my car for the first time and I am embarrassed to say that I did not check my gap. After I installed the new plugs I tried to start my car and it would crank all day long but not start. After pulling the plugs I noticed my mistake. I re-installed the old plugs but my car still wouldn't start. My car was running and driving just fine up until I changed the plugs. The gap on the new plugs was too small, by a lot. Can anyone help me with this? Gas was on, key was on, just wouldn't catch. I am thinking along the lines of the condenser or coil, but those are just guesses. |
04-03-2013, 09:50 PM | #2 |
Re: Need help with new guy mistake.
The first thing I would check is spark at the points. Rotate the engine with the crank and the distributor cap off until the points are closed. Turn the key on and open and close the points manually to see if you have sparking at the points.
Al |
04-03-2013, 09:51 PM | #3 |
i am not trying to be a smart ass but did you turn the key on?
if no spark at the coil wire holding it close to a head nut then::: if you have a fuse at the starter make sure it didnt blow make sure rotor turns when cranking engine clean and check point gap |
04-03-2013, 09:55 PM | #4 |
I am also not trying to be a smart guy but did yiou turn the gas valve on ?
Al |
04-03-2013, 10:01 PM | #5 |
He did mention that the SW and gas was on
04-03-2013, 10:04 PM | #6 |
04-03-2013, 11:50 PM | #7 |
Mitchell, better let Parker read for you LODL!
Buster T.
04-03-2013, 10:04 PM | #8 |
When messing with the spark plugs did you somehow get the distributor messed up? Like maybe the high voltage wire unplugged, etc.
04-03-2013, 10:09 PM | #9 |
Didn't happen to leave the rotor off, did you?
I've seen it happen more than once, and I've also done it. |
04-03-2013, 11:23 PM | #10 |
were the plugs wet when you pulled the new ones?put plug wire on one plug and lay it against the head and turn engine over does the plug fire? if not go back to the start, make sure you have juice to switch, then to coil, then to dist, if yes then check condensor and coil
04-03-2013, 11:43 PM | #11 |
OUT OF GAS???????? Happend to me just after rebuilding the carb & wouldn't even FART, not even once!! (Dog's Laughin') Bill W.
04-04-2013, 12:01 AM | #12 |
After cranking all day with the plugs that wouldn't fire you probably flooded the engine. Let it sit until tomorrow and try to start it with the old plugs. Open the throttle all the way while cranking.
Tom Endy |
04-04-2013, 12:11 AM | #13 | |
I always start with the easiest check first, just hold the coil wire 1/4" from a head nut and see if you get a nice blue spark while cranking the engine. Two years ago my car wouldn't fire after setting for 6 weeks during a very rainy season. I figured with the high humidity and setting for 6 weeks might have left some corrosion on the contacts so I sanded them, but still no go while using the starter. I hand cranked it and it fired right off on the first pull. After running a couple minutes I shut it off and tried the starter again. Everything was now fine. |
04-04-2013, 12:14 AM | #14 |
Re points I prefer to use a test light on the dist side of the coil. Crank the engine over and see if the light is going on and off...Now while your at it put the test on the other side of coil and see if it lights.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
04-04-2013, 01:21 AM | #15 |
OK Marine! Let's do it by the numbers...assuming the new plugs are correct.
You remember what the Corps taught us about assuming! 1. check battery voltage 2. turn key on 3. check voltage to the coil 4. check output of the coil 5. check pionts gapped properly 6. plugs gapped properly 7. check spark at plugs 8. check engine timing for #1 cylinder at TDC 9. gas valve open 10. start engine This may sound crazy to you, but I would check the sides of the plugs to be sure they are clean. When I was a teenager I would prank my buddies by using a lead pencil and drawing a line down the side of their plugs, causing them much frustration when their cars wouldn't start.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls '41 Fordor Deluxe / 2-duece flattie '66 1/2 Dodge Charger '14 100th Anniversary Challenger Limited Edition. Semper Fidelis |
04-04-2013, 02:17 AM | #16 |
If nothing was changed but plugs, it has to be something really simple like a blown fuse. Do the headlights or horn work? It's possible that the coil or ignition switch etc crapped out on you but what's the odds of that happening at the exact moment you changed the plugs. Your car didn't fall apart because of the simple act of changing the plugs. Again not being an ass but when you put the plugs back in, you did reattach the copper plug wires?
DMAFC |
04-04-2013, 03:04 AM | #17 |
Hornbuckle, you were a rascallion!! Me too! I would put a tiny pebble inside the valve stem cap & screw it on tight!!----------a VERY slow sssssssssssssst & flat!!! Oh & those car bombs with 2 skinny wires, one to a plug connector & one to a ground!! Installed in 7 seconds & don't slam the hood hard or they'll catch you & beat the CRAP out of you!! Bill W. (Sorta' like the guy was fightin' with his wife & said, "I don't want to see you for 2 weeks"! After 13 1/2 days, he could barely see a slit of light from his left eye!)
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 04-04-2013 at 03:10 AM. |
04-04-2013, 04:05 AM | #18 |
Yo, Marine Dude, Chief always gapped points with a WORN dime & gapped the plugs with a "FRESH" nickle, seriously!
Bill W.
04-04-2013, 08:26 AM | #19 |
04-04-2013, 09:31 AM | #20 |
My Dad would use a match book cover for the points and the thickness of the paper match for the plugs.
