05-06-2016, 09:00 PM | #1 |
Sacrificial anode?
Got aluminum heads on '36 LB engine what can I use to slow down or stop electrolysis? Going to use graphite head gaskets now.
05-06-2016, 09:15 PM | #2 |
Re: Sacrificial anode?
I use radiator caps that have the sacrificial anode attached. Now if I can recall the name. Maybe Rad Cap?
05-06-2016, 09:29 PM | #3 |
i get anodes at a marine store and screw them into the water pump or xtra hole at water neck.they have all sizes.
05-06-2016, 09:47 PM | #4 |
Most modern antifreezes mixed with distilled water are compatible with and protect aluminum components.
Jack E/NJ |
05-06-2016, 11:01 PM | #5 | |
I see Summit has the Rad Cap, will order one. Last edited by 36tudordeluxe; 05-07-2016 at 12:05 AM. |
05-07-2016, 07:17 AM | #6 |
05-07-2016, 07:24 AM | #7 |
Here's another alternative: http://www.no-rosion.com/norosioncoolant.htm
05-07-2016, 07:35 AM | #8 |
Here is what I and a few others use. A friend who has aluminum heads and radiator uses them up pretty quickly, maybe once a year. The anode is replaceable.
http://www.ve-labs.net/products/rad-cap |
05-07-2016, 08:13 AM | #9 |
05-07-2016, 08:30 AM | #10 |
For aspiring chemists and those who like clear cut 'yes-and-no' type answers to their questions. 8^)
http://www.overclockers.com/pc-water...istry-part-ii/ Jack E/NJ |
05-07-2016, 09:08 AM | #11 |
Jack, Thanks for posting that article. It is excellent info.
