05-05-2016, 10:13 AM | #1 |
Original gauge rebuilding services?
I'm working on a 1935 Convertible Sedan at the shop and it is in need of having the water temperature gauge repaired as the capillary tube has been cut off at the back of the gauge housing.
I also have a customer with a 1935 Fordor that needs the fuel gauge repaired as the tube the connects from the bottom of the glass to the bottom of the rear is plugged solid. Can anyone recommend a repair service for these gauges? Thanks!
Early V8 Garage - West Covina, CA |
05-05-2016, 10:22 AM | #2 |
Re: Original gauge rebuilding services?
I think R & S in Arizona can.
05-05-2016, 10:33 AM | #3 |
Williamson's Instruments in Chester,Arkansas.About $250 to repair the temp gauge.479-369-2551.Early Ford Store sometimes has orig in stock.Originals are out there at about $300 +.I can fix the fuel if not to messed up.send me an email w/phone number.
05-05-2016, 12:16 PM | #4 |
You might give Bob's Speedometer a call 1800 592 9673. He did my speedometer and I am very pleased with the work and turn around. Per their website they fix gauges also.
05-05-2016, 12:34 PM | #5 |
As Deuce lover stated most places charge 250-up to repair temp gauges. If you are unable to find someone.. We stock NOS ones as well as Reproduction ones.
05-05-2016, 01:23 PM | #6 |
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. |
05-05-2016, 02:27 PM | #7 |
Morris Gauge has been mentioned on Fordbarn quite a few times.
05-05-2016, 03:24 PM | #8 |
I'm using Williamson's - really great people and prices seem to be fair. Talk to Ron - good guy in general.
Williamson's Instruments, Inc. 2018 E. Front Ave. Chester, Arkansas 72934 www.williamsons.com [email protected] |
05-05-2016, 10:53 PM | #9 |
Hey Dennis if you find some one let me know ! I was told that the chemical that was used is banned and no Longer made and that the substitute will not read correctly about 20 degrees off !!! Look into it ! Hey bye the way the 36 battery box master bracket is first class and fit like a glove ! U da man !
05-06-2016, 07:24 AM | #10 |
I too had a very good experience with Ron at Williamsons putting a new thermocouple on a vintage SW gauge. All that work is pretty expensive no matter who does it. Quality work is worth investment.
05-06-2016, 09:39 AM | #11 |
