Old 10-28-2019, 12:21 PM   #1
30aadoodlebug
30aadoodlebug's Avatar
Default Basket Case 50 Club Coupe
Fortunately this is not my car, but a car a friend just bought (Which I advised against.)
The car ran one week ago when my friend went to look at the vehicle. I use that term loosely. Ran for four minutes and then died.
The car was running with the battery changed to negative ground. That was so the original owner could run an electric fuel pump.
It doesn't run now. The distributor is wired 180 degrees backwards. The car goes to start, but as soon as she fires there is a large clunk from the front of the engine and she dies. Im rewiring the car back to the original firing order today, but that hard clunk and then no tart has me pretty worried.
Also, it is not an 8ba, but a 52-53 EAB.
Thanks in advance gents
30aadoodlebug is offline   Reply With Quote
Old 10-28-2019, 06:11 PM   #2
corvette8n
corvette8n's Avatar
Default Re: Basket Case 50 Club Coupe
Is it 12 volt?, or 6 volt negative ground. You will need to get the wiring straightened out, does it really need the electric pump to run? If not leave it out of the equation for now. Make sure coil is correct and working, points set and Condensor replaced. Once you get that going then work on the fuel.
Old 10-28-2019, 06:54 PM   #3
34PKUP
34PKUP's Avatar
If the picture you show is after correcting, at least the passenger side appears to be wired correctly.
34PKUP is offline   Reply With Quote
Old 10-28-2019, 07:14 PM   #4
tubman
tubman's Avatar
You do realize don't you, that Ford flathead cylinders are numbered differently than most other V8 engines. Where the others have even numbered cylinders on one side and odd numbered cylinders on the other, Ford flatheads are numbered 1-2-3-4 from front to back on the passenger (distributor) side, and 5-6-7-8 on the other.
I have helped several flathead guys over the years who had wired their cars with the wrong cylinder numbering.
Old 10-28-2019, 10:13 PM   #5
slowforty
slowforty's Avatar
For the fuel pump,with positive ground, just reverse the wires.
slowforty is offline   Reply With Quote
Old 12-02-2019, 12:07 PM   #6
30aadoodlebug
Hey All,
Sorry for such the delayed response on my end. Yes, I know the proper firing order of flat heads. My friend and I have done some work to the car recently, and the only time the car fired was while checking for spark with the number 2 plug out of the head checking for ground. Could a stuck cutout or shorted out generator cause the car to not fire?
Thanks for all the help!
Old 12-02-2019, 01:16 PM   #7
4t7heaven
That "clunk" could be the distributor. I would pull it and take a look at the gears.
4t7heaven is offline   Reply With Quote
Old 12-02-2019, 04:09 PM   #8
19Fordy
19Fordy's Avatar
Do not crank the engine with the distributor removed.
