02-09-2021, 05:02 AM | #1 |
Caged Nuts needed
Anyone out there know if any body is making 3/8 -24 square nuts and stamped cages. Roy Nacewicz, sold them, but he has past away.
02-09-2021, 05:08 AM | #2 |
Re: Caged Nuts needed
Check with Michael as he took over Roy's business. Here's a link to caged nut from his website. A call works great as he's one of the few that will actually take the time to talk to customers. https://thirdgenauto.com/product/new...-nut-assembly/
02-09-2021, 07:28 AM | #3 |
Bob Drake was selling different size square caged nuts at one time.
02-09-2021, 07:46 AM | #4 |
Like GaryU suggests above.....CALL and ask for MICHAEL Driskell at 3rd Gen! DD (844) 327-5988 |
02-09-2021, 08:46 AM | #5 |
If you are talking about the 'weld in' caged nuts that are available, then just tack welding on a standard nut should serve the same purpose.
02-09-2021, 09:58 AM | #6 |
02-09-2021, 10:38 AM | #7 |
McMaster-Carr has them PN 90955A120, 5 for about $13.
02-09-2021, 11:22 AM | #8 |
We have the correct ones Roy had. I am discontinuing them and would make you a smoking deal!
02-09-2021, 11:36 AM | #9 |
Mike I’m in for some. What sizes do you have. Thanks. Cheers
Tony |
02-09-2021, 06:41 PM | #10 |
Me too!
02-10-2021, 07:27 AM | #11 |
Me too.
02-10-2021, 08:16 AM | #12 |
1/4 5/16 3/8 and 7/16 although most all the 1/4’s sold out yesterday
02-10-2021, 10:24 AM | #13 |
I think I need 5/16 for fender attachment on an 37, will have to check.
02-10-2021, 11:02 AM | #14 |
02-10-2021, 01:41 PM | #15 |
Question, what type caged nuts are you speaking of? (weld on or clip in?}
02-10-2021, 02:34 PM | #16 |
Weld on I don’t think the acme style clip ins came about until 49
02-10-2021, 08:26 PM | #17 |
Michael,
One advantage of the original version is that it provides a little bit of wiggle room so that the nut can be moved around slightly making it easier to start the bolt in the nut, especially when attaching rear fenders. Judging from the C&G catalog image and others of the modern version, the nuts are fixed in place with tabs. With either type it helps if the bolts are like the originals with a slight taper at the threaded end of the bolt. |
02-11-2021, 05:58 AM | #18 |
Michael,
I am after 12 3/8-24nuts and cages for my 40 Tudor, m sons40 Delivery and grandsons 39 I am in Australia, have emailed you with Roy’s part no. For bolts 3/8 and 5/16 . |
02-14-2021, 09:26 AM | #19 |
How many do you need as I have a few in my parts bin
Wanted flathead speed equipment Thanks |
