11-12-2018, 02:16 PM | #1 |
Fuel delivery issues
My 36 Phaeton is giving me fits. It seems to run out of fuel and stop by the side of the road. Put one of Bubba’s condensers on it, rebuilt the Strom 97, tried three different fuel pumps. The old flexible fuel line would turn on the brass fittings so I tried putting a clear line on and made sure that I wasn’t getting vacuum leaks. She quit again today on the way to the Veterns Day parade. I’m getting what looks to be air bubbles in the line when I believe that it should not have bubbles in it. I’m running Marine gas in it. I’ve attached a photo showing the fuel and either air or a vacuum void. I’m sure wiser minds than mine will know the answer.
11-12-2018, 02:31 PM | #2 |
Re: Fuel delivery issues
My 36 pu had a rubber gas line all to tank,did same thing,go about 5 miles and quit,put metal line in and problem went away,,check for some rubber tubing in line!!!
DON P |
11-12-2018, 03:03 PM | #3 |
Is that clear line clamped tight? By the way, that clear line is a fire hazard. Over time it becomes brittle, cracks and leaks. Don't want your car to go up in smoke.
11-12-2018, 03:16 PM | #4 |
Clear fuel line is a temporary shade tree mechanic diagnostic tool. I have two new Carpenter ones, both Chinese to install once I’ll got this gremlin gone. Steel line all the way to the tank. I’ll try a new Ferrell and......
11-12-2018, 03:23 PM | #5 |
Is the gas cap vented ? Just a wild guess . Could you try running with another cap or without one .
11-12-2018, 05:10 PM | #6 |
Turned out to be the brass fitting on top of the sender unit thing on top of the tank where the fuel line screws into, it was cracked around the pipe connection that connects the brass fitting to the small pipe going into the tank .hard to find but an easy fix. Lawrie Last edited by Lawrie; 11-12-2018 at 05:14 PM. Reason: spelling |
11-12-2018, 05:13 PM | #7 |
Check the gasket on the glass bowl. A cracked or leaking gasket will cause air to be sucked into the system giving similar symptoms.
11-12-2018, 06:11 PM | #8 |
The air in the line in the photo posted is prior to the fuel entering the fuel pump. There is a leak somewhere in the fuel line or one of the fittings.
11-12-2018, 09:44 PM | #9 |
As previously stated, check the cork gasket on the fuel bowl.
11-12-2018, 09:49 PM | #10 |
Maybe I'm not understanding something, how can a leak in the fuel bowl gasket cause air bubbles in the input line to the fuel bowl? Would not that cause air in the line after the fuel bowl? What am I not understanding here?
11-12-2018, 09:53 PM | #11 |
I know teflon tape is considered a bastard fix. But if you use it 3/4 threads back it wont get into to system and seal. But if the fitting is stripped on the pump no amount of anything will fix that.
You can't go wrong with a new line tank to flex hose. I usually do it because its cheap insurance. Might be a pin hole. Air is coming from the tank forward would be my guess. It's weird on a yblock I had the clear fuel filter never seemed to fill but yet the thing ran like a beast. Lastly... Does it leave you stranded after 30min of driving? Coil? Just more to add... Last edited by Tinker; 11-12-2018 at 10:07 PM. |
11-12-2018, 10:53 PM | #12 |
Any air bubbles in the fuel bowl will rise to the highest point in the system, which would be the top of the input fuel line.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 11-12-2018 at 10:59 PM. |
11-12-2018, 11:00 PM | #13 |
If the check valves are leaking. Right???
Napa sells flat cork sheets, cheap. X-acto blade cutout. . Last edited by Tinker; 11-12-2018 at 11:15 PM. |
11-13-2018, 03:44 PM | #14 |
Culprit all along has most likely been the flexible fuel line. Removed my clear line and I’m now suspicious that I didn’t have it clamped tight enough. Installed a new DC flexible line and she is purring like a kitten. We’ll see on the next road trip. Thanks to all who chimed in with thoughts and suggestions.
John |
11-13-2018, 07:55 PM | #15 |
Good news!
11-14-2018, 12:22 PM | #16 |
Yet another satisfying trouble shooting project.....you have to love it when that happens!!!
