12-15-2013, 09:54 PM | #1 |
Ring gear and Starter motor blues
At the end of the summer I though I was feeling a bit more vibration than usual, so for that and other reasons, pulled the engine. Found that the ring gear was partially loose, one side was about 1/4 inch off the flywheel flange. The teeth were chewed a bit. Maybe a bad gear or improper installation, so have ordered a new gear.
But, its a 12 volt system with a 6.5 compression ratio, and it whacks pretty good when starting, turns fast, so wondered about the starter wiring. Forum search turns up that a 12v starter should be wired in series not parallel. I got the starter a long time ago, supposed to be a 56 Ford 12v case, flathead armature, Model A end cap. The wiring diagram of what I found is I hope attached. It seems two coils are is wired parallel. There are only 3 coils. Two are heavy copper, in parallel, the third is 16 gauge wire. Are only two big coils correct? What is the purpose of the small coil? How do you run a connector from the first big coil to the second so they are in series? Should I start from scratch with a 12v starter. What say the experts? To avoid questions about just putting in a stock 6v starter, I don't want to do that because I suspect it is now wired as a 6v starter and it hits too hard and the ring gear is loose. I think the HC head is a problem. I have the heavy duty starter drive. Thanks to all. |
12-15-2013, 10:41 PM | #2 |
Re: Ring gear and Starter motor blues
You can take your flywheel to a machine shop and have a new ring gear installed and pinned in place so it won't ride forward. Remember to instruct the shop that the tapered teeth on the ring gear face aft.
Install a 12-volt Model A starter. Tom Endy |
12-15-2013, 10:52 PM | #3 |
Three coils and one empty shoe? That's one messed up starter!
EDIT: Perhaps not (see addition below this diagram) Tom W said he has seen a Ford starter with an empty shoe and one finer reverse winding, likely for limiting speed. I found this drawing of several configurations, look at the lower right. In any case I'd feel more comfortable with the tried-and-true configuration that has no fine-wire coil! Last edited by MikeK; 12-16-2013 at 12:59 AM. |
12-16-2013, 11:39 AM | #4 |
Thanks for the responses, which really help.
Tom, the pins are great, I'll do it. Mike, thaks for the drawings. I could not find any. I think your "one messed up starter" is right. Mine seems mostly like a modifed "d" in your diagrams. If I had a lower compression motor I would probably rewire the starter, but with the HC head I think I will get Snyders reduction gear starter, less impact, more torque. And hey, I have been trying to decide on a Christmas present for myself anyway. |
12-17-2013, 01:39 PM | #5 |
I have three starters with only three coils. They have two heavy coils 180° apart, an empty
shoe and 180° from that a lite shunt coil. The starters are for 59-62 Ford diesel tractors so they are very high compression engines. Bob Last edited by Bob C; 12-17-2013 at 04:49 PM. |
12-17-2013, 04:39 PM | #6 |
Thread Tools | |
Display Modes | |
