08-01-2017, 06:21 PM | #1 |
Switched parking brake lever
I switched out my parking brake lever to the earlier pistol grip kind. It is much easier on my thumb than the other button kind. I know they were not used in 29, but since they predate the button type it could have been put on by a dealer. I kept the old one so I can always put it back.
08-01-2017, 06:24 PM | #2 |
Re: Switched parking brake lever
Actually, since your e brake is located in front of the shifter, it could have been either style. My '28 has the same as that in front of the shifter.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
08-01-2017, 08:26 PM | #3 | |
BTW I always call it a parking brake because I have heard if you try to use it as an e brake you could be in a world of trouble - true - not true? |
08-01-2017, 08:35 PM | #4 |
The Standards say they went to the button in January 1929.
Bob |
08-01-2017, 08:35 PM | #5 |
Oh, so True, I too have been told this by Randy Gross who rebuilt mine. Let me see if I can find the reference I have for the brake handles.
08-01-2017, 08:54 PM | #6 | |
I think if you are in a position to need an emergency brake, then the parking brake will do, if you don't happen to have an anchor
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
08-01-2017, 08:55 PM | #7 |
Well, after looking through what I have, the first mention of the brake lever in front of the shifter is June 28, and there is no other mention until April 29 when it appears the handle was placed to the right of the trans shifter with the push button style. So, do you have any dates on your gas tank? Or do you have the number off the frame or engine to find an assembly date?
If it is between June '28 and April '29, you are good to go with the pistol grip.
08-01-2017, 09:05 PM | #8 |
From the Standards 6-7 "From January 1929 through July 1929 the hand brake lever was a push button type and it was mounted forward of the gear shift."
Bob |
08-01-2017, 09:49 PM | #9 |
You are correct, but there is nothing mentioned in the Service Bulletins about the change until April.
08-01-2017, 10:31 PM | #10 |
In the Restoration Guidelines they refer to it as the "emergency brake", however I prefer to call it the parking brake that doesn't do worth a s##t for parking. this is on page 7-2 Revised 2011 at the top of the page. A lot of details on cross shafts, return springs. Specifically on the first page AREA 7- BRAKE SYSTEM DOES NOT INCLUDE: Emergency brake handle, stop light switch or lights.
I say use whatever suits your fancy. As Bob C mentioned in post #8, from January 1929 through July 1929 push button type. These are just guidelines they use for judging. Myself I like the looks of the handle instead of the button but I'm too cheap to change it right now. |
08-02-2017, 02:47 AM | #11 |
As a matter of interest is it a straight swap to change the e brake handle so it could be returned to original, I would prefer the early type on my `30 coupe, although finding one over here is unlikely.............
Love a Lot, Trust a Few
Always Paddle Your Own Canoe |
08-02-2017, 06:20 AM | #12 | |
08-02-2017, 06:28 AM | #13 |
Yes but. I had to switch the pawl (which was different) from my button lever to the grip lever to allow it to go forward enough for the Pin to slip back into the parking brake rod. (The "pawl" is the the moving hook part - right?)
08-02-2017, 08:01 AM | #14 |
looks nice, i can deff see how the button type might be hard for some.
FYI to debate over parking brake or emergency brake refer to the owners manual on the 6th page under specifications specifically BRAKES: Four wheel internal expanding service brakes operated by the foot brake pedal. Also an emergency or parking brake on both rear wheels operated by the emergency brake lever. The emergency brakes are entirely separate and distinct from the four wheel service brakes. but yes its a one maybe 2 time use emergency brakes before things get bent and bound up...
1929 Model AA - Need long splash aprons! |
08-02-2017, 08:58 AM | #15 |
I too have the pistol grip in front of tranny and love it but used it because I put the manual shift lever for my Columbia two speed two the right of shifter position.
08-02-2017, 09:12 AM | #16 |
Vermin is a June '29 & has the pistol grip in the front, out of the way & easy to work.
Bill Screech
08-02-2017, 10:25 AM | #17 |
I suppose you know the trick of pulling the brake lever back slightly to take pressure off the pawl when you release it - makes it easier to press the button. Works on that type - dunno about the squeeze type.
As for using it as an emergency brake, I remember one time I was doing 35 - 40 in my 30 CCPU - probably a little too fast for the street I was on and the car in front stopped short. I saw the mechanical service brake wasn't going to get me stopped in time so I gave the emergency/parking brake a good yank - locked up the rear wheels real quick! That was a good thing in my case as it saved my front end - or more likely the rear end of the modern tin can car in front of me. But yeah, I can see it might make things worse in a different situation. |
08-02-2017, 10:43 AM | #18 |
Thanks for that.................
08-02-2017, 08:58 PM | #19 |
Yes, but in my case I have to ratchet on the parking brake real tight to get to hold well. So tight, that pulling it back to release the pawl and pressing the button at the same time is difficult. The squeeze grip is much easier. My guess is Ford made the change because the button type was cheaper to produce.
08-03-2017, 12:35 AM | #20 |
Here in NZ we call them the hand brake and the foot brake. Much simpler.
Thread Tools | |
Display Modes | |
