06-10-2013, 09:59 PM | #1 |
Carburator adjustment
I now have the engine running and would like to adjust the carburator properly. I have a tillotson carburator which I have throughly cleaned and replaced all the necessary pieces. I made sure the intake flange surface was flat. I think I understand how the fuel adjustment in the cab should be set, off, 1/8 or 1/4 turn when warmed up but I am unsure how to adjust the other mixture screw.
Many years ago when I worked in the garage we would put a vacumm gauge on an engine and adjust the carb for maximun vacuum. Can I still adjust this way? I spent several hours searching the forum for carburator information but it appears the Zenth carburator is more common. Any advice is greatly appreciated. Thanks Mike |
06-11-2013, 05:55 AM | #2 |
Re: Carburator adjustment
Did you get the passages clean ? Usually the main jet needs to come out to make sure the 2 transition ports are clean and that jet does not want to come out on some and needs to be drilled out and replaced. |
