Old 09-09-2021, 12:34 PM   #1
mike37cdn
Default 3.54 gears in a30 ford 4 door
changing the gears in the 30 a rear end 3.96 came out putting in 3.54 the gear is bigger on the 3.54 what has to be done on the rear end house to get the gears to work thanks Mike
mike37cdn is offline   Reply With Quote
Old 09-09-2021, 12:45 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: 3.54 gears in a30 ford 4 door
The standard rear end ratio for a 1930 is 3.78:1, not 3.96:1. Do you have a stock Model A rear axle? If not, then Model A ring and pinion won't fit.
Mike Peters is offline   Reply With Quote
Old 09-09-2021, 12:46 PM   #3
Keith True
Keith True's Avatar
I've never heard of a 3.96 ratio in an A,but it doesn't matter,the 3.54 just bolts in.No modifications needed.I have them in 3 cars.
Old 09-09-2021, 01:17 PM   #4
mike37cdn
it might be 4.11 not sure 9:37 gear count came out went to put it in and the gear is hitting the stop were the bearing race sits
Old 09-09-2021, 02:38 PM   #5
Patrick L.
Patrick L.'s Avatar
9:37= 4.11, 9:34=3.78, 11:39= 3.54
The ring gear should be the same size
