07-08-2021, 06:12 PM | #1 |
Generator and fan setup 59 AB
Would someone please post a photo of a stock generator and fan mounting for a 59AB? I currently have a34 with a 59AB and alternator, want to return to a stock generator. Addendum: does this look like the stock mount and fan?
Tim Carlig Last edited by dean333; 07-08-2021 at 07:43 PM. |
07-08-2021, 09:16 PM | #2 | |
Re: Generator and fan setup 59 AB
Dean ......What you have there in the picture appears to be an aftermarket bracket to mount an alternator on a flathead Ford manifold. 59AB Ford engines did NOT have a generator-mounted fan, as can be seen in this picture of a 59AB type engine. The second picture shows an earlier generator pully mount for a fan. DD |
07-08-2021, 10:40 PM | #3 |
Nice and simple engine stand,V8 Coopman
07-09-2021, 12:58 AM | #4 |
Yes it is, but unfortunately, it ain't mine. Just a perfectly-representative picture that I chanced-upon on the ol' interweb. DD |
07-09-2021, 01:03 AM | #5 |
59ab is not the stock engine for your '34, will you have clearance to the radiator with the stock hub/bracket mounted fan? I have a 59a in my '38 and have the fan mounted on the generator.
Sometimes, ingenuity gets in the way of sense and sanity. |
07-09-2021, 01:40 AM | #6 | |
The STOCK fan hub on a 59AB was first introduced in 1942. The picture below shows how far forward it protrudes on the engine. There is nowhere near the clearance with the REARWARD-slanting '34 radiator as there is in a '42 thru '48 Ford with it's straight-up standing radiator. Apparently, since you are already running an alternator, you need an alternator pulley that is drilled and tapped to accept a Ford fan, like the one shown below from SPEEDWAY MOTORS. Click the link BELOW for the Speedway advertisement. Hopefully, this will help. With more questions, just holler back. DD https://www.speedwaymotors.com/Offen...ord,25025.html ...... |
07-09-2021, 01:53 AM | #7 |
V8coopman, good point. I bought the car with the alternator already installed, I want to put a generator back on as I don’t like the look of the alternator. The stock 59AB fan is not mounted on the generator but further down so there’s a little more room. I measured 6” from the front surface of the intake to the radiator.
Tim Carlig Last edited by dean333; 07-09-2021 at 02:02 AM. |
07-09-2021, 02:07 AM | #8 |
Tim,
Ck your PM's. Charlie ny |
07-09-2021, 09:30 AM | #9 | |
07-09-2021, 10:36 AM | #10 | |
Will ....As you likely know, a 59AB is essentially the same physical size as a '34-type flathead. It's the 59AB-type hub and fan assembly that takes-up too much room to fit ANY flathead in a '34 Ford. In fact, that hub/fan assembly won't fit into any of the earlier, slanted radiator Fords. It is a massive assembly to be avoided for most of the '30s Fords, as seen below. BELOW is a 59AB-type engine with a GENERATOR-MOUNTED fan. DD |
07-09-2021, 10:59 AM | #11 | |
My 59a in the '38 has a generator mounted fan and the stock hub fan definitely would not fit.
07-09-2021, 11:08 AM | #12 |
Will a stock 34 generator fit on a 59AB engine?? Thanks
Tim Carlig |
07-09-2021, 11:35 AM | #13 |
The early stock generators mount the same. They have a tang that fits into a slot in the intake manifold. This is the same if its a fan mount gen or a 59A style mount.
07-09-2021, 11:40 AM | #14 |
38bil, only 34 and up. 32 and 33 unique, only fit those years. Found this out since my post. Thanks
Tim Carlig |
07-09-2021, 11:44 AM | #15 |
My 34 has a 59ab, with an EJ Whitney alternator conversion. They convert your stock 34 gennie, which fits on the 59, to an alternator. Not cheap, Not a lot of amps, but fits the stock fan, radiator , and looks correct
07-09-2021, 12:48 PM | #16 |
The car I just bought HAS an alternator which I’m removing in favor of the stock generator. I’m a purist. Alternator and bracket I’m selling for $195, $249 from vendors.
Tim Carlig |
07-09-2021, 01:07 PM | #17 |
If you're that much of a "purist", that "59AB" is gonna stick-out like a sore thumb to any enthusiast with an inkling of knowledge. Who knows....it's possible that the previous owner utilized that alternator 'cuz the generator wouldn't carry headlights at night, for instance. Ya ain't gonna fool the crowd to any degree by replacing the alternator for a gen. If it were me, I'd paint the alternator semi-gloss black, and keep on truckin'! DD |
07-09-2021, 01:43 PM | #18 |
Any chance you could mount the fan on the c/shaft like a 40??
Paul in CT |
07-09-2021, 01:55 PM | #19 | |
It would have to have the extended-snout crankshaft for that to work, plus....there just ain't room in a '34 for a crank-mounted fan. DD |
07-10-2021, 09:15 AM | #20 |
Point taken Coop, just don’t like the look of an alternator. Thanks all.
Tim Carlig |
