01-17-2018, 11:35 AM | #1 |
Floor Board Felt Strip Installation
I have seen from pictures that each of the two floorboards have a felt strip installed around each.
Question, is there any felt strip applied between the two wood pieces? (arrow). Thanks, |
01-17-2018, 12:19 PM | #2 |
Re: Floor Board Felt Strip Installation
I don't believe so. I have some original floorboards and I don't see any remnants of webbing or tacks.
Rusty Nelson |
01-17-2018, 12:34 PM | #3 |
not normally . maybe a personal touch
V4f |
01-17-2018, 04:30 PM | #4 |
They came original with webbing installed (but not at the
at the mating edges of either board where the arrow in the picture points) Last edited by Joop; 01-17-2018 at 04:38 PM. |
01-17-2018, 08:29 PM | #5 |
I used staples on mine. Worked fine.
01-17-2018, 09:22 PM | #6 |
I know the voices aren't real but damn they have some good ideas! |
01-18-2018, 02:52 AM | #7 |
When I built my floor boards I wrapped felt around the entire lower section.
figured it would stop any squeaks. There was no problem with fit, as as it installed perfectly. So I guess it is a personal choice.
01-18-2018, 08:37 AM | #8 |
The floorboard thickness is to be 11/16" thick. The felt strip that goes around the floorboards is 2" thick.
So, to install the felt strip correctly, is it mounted flush with the top and folds down and on the bottom, or is the felt mounted flush with the bottom and folds up and over the top? Thanks |
01-18-2018, 09:50 AM | #9 |
So, to install the felt strip correctly, is it mounted flush with the top and folds down and on the bottom.
That is the correct way. |
01-18-2018, 09:51 AM | #10 | |
01-18-2018, 10:00 AM | #11 |
I pulled it nice and tight around all edges, secured it down with staples, trimmed off the excess on top and bottom with a nice new razor blade. It was tight, clean and secure.
The felt strip is nowhere near 2" thick. When pulled tight it is thinner then it is when static. Note: I did not use the felt in the transmission cut-out or the battery access hole, just the mating surfaces.
01-18-2018, 10:58 AM | #12 |
Good Morning...I have a set of floorboards done in the 1970's and they have a felt strip all around that is the same width as the floorboards and the felt was attached with long thin nails. Enrie
01-19-2018, 03:22 AM | #13 |
The original welt for the floorboards is more like about 1 1/2" wide. It's fastened with small tacks (nails), so it's level with the top side. The bottom side is folded in the corners, so it's 3 layers thick in the corners. You'd think the corners would have been mitered, but my original early 29 Tudor boards aren't.
