Old 05-16-2019, 08:15 AM   #1
Standing Elk
Default tire pressure
What pressure should there be in bias ply 19" tires?
Standing Elk is offline   Reply With Quote
Old 05-16-2019, 08:33 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: tire pressure
I believe that all the model A tires had a recommended pressure of 35 psi but it will vary with loading conditions as well.
Old 05-16-2019, 01:43 PM   #3
leo
leo's Avatar
My Goodrich repro's say max pressure of 32 psi.
leo is offline   Reply With Quote
Old 05-16-2019, 01:49 PM   #4
1930artdeco
1930artdeco's Avatar
I use about 40. That way it takes a loooong time to leak down. That and the tubes don't shift at all. That is my story and I am sticking to it.
Mike
1930 TownSedan (Briggs)
Still learning after all these years....
Old 05-16-2019, 02:07 PM   #5
duke36
What's your location elevation? At 5000 ft. or so, you would read about 2psi higher than at sea level. I use a home made oxygen gauge that is much more accurate than most, so the polyester or nylon bias would read 35psi at sea level. Tires gain about 3 to 5 psi when hot so over inflation is not usually a good thing.
Old 05-16-2019, 03:23 PM   #6
Werner
Werner's Avatar
I use 40 PSI in Goodrich. Then the car goes better straight ahed.
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 05-16-2019, 04:12 PM   #7
HDowse
HDowse's Avatar
I think it depends somewhat on the model. The coupes and pickups are light and 34# seems about right. In my ‘28 Leatherback I experimented with 35 all around and found the car oversteered on mild to sharp corners. That is, the back end felt like it wanted to break loose. So I dropped the fronts to 34 and raised the back to 38 and the car was much more comfortable in turns. Your experience may vary, of course, but the heavier sedans seem to do better with more pressure in the rear tires.
HDowse is offline   Reply With Quote
Old 05-16-2019, 06:05 PM   #8
eagle
eagle's Avatar
I run 42 at least. Fordor so its heavier than most. Tires wear more evenly with the higher pressure, and better ride.
Old 05-17-2019, 08:53 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
On my Victoria, I run 35 psig in the front tires to ease the steering effort, and I run 28 psig in the rear tires for a softer ride.
On my Coupe, I run 1932 6.00 x 18 tires with 40 psig in the front and 28 psig in the rear tires.
Bob Bidonde
Old 05-29-2019, 09:23 PM   #10
alandomer
I've been running at 40psi on my bfgoodrich tire. This psi seems nice and comfortable.
alandomer is offline   Reply With Quote
