04-14-2018, 01:36 PM | #1 |
Thermostat housing gasket
I know I should know but forgot😁I know newer ford cars use same gasket making it easy to get at parts store. I had to pull a sticking thermo & am in a jam & need a gasket to get back on the rd. I’m in a parts store parking lot so, help. I’m thinking I remember a 289 ford uses same?help
Nomad |
04-14-2018, 02:16 PM | #2 |
Re: Thermostat housing gasket
Buy some gasket material and make your own . Just trace the t-stat housing .
04-14-2018, 02:18 PM | #3 |
Straight 6 or V8 65-95 fits after some scissor work...taking that extra ear away.
Atleast that is what comes in some of the felpro kits for flatheads today. |
04-14-2018, 03:04 PM | #4 |
Do like Ford Freak suggested. Easy to make and you'll have gasket material for more, if needed. Buy thick gasket material so it seats really good.
04-14-2018, 03:42 PM | #5 |
If you have a late flathead you might check to see if the gasket from an early Chevrolet V-8 will work.
04-14-2018, 03:54 PM | #6 |
Stant 25138 with adhesive already applied - holds the stat in place when installing the housing.
Making the simple complicated for over 30 years. |
04-14-2018, 04:20 PM | #7 |
flatheadmurre, bingo used a ‘67 mustang 289 gasket. Fit worked great. Got me to the Rod Run & home. Will do the trim work tomorrow with exacting blade.
Nomad |
04-14-2018, 10:15 PM | #8 |
Glad to hear you got 'er going and made it to the event . - F F
