03-13-2013, 10:30 AM | #1 |
Anyone running a 3.25 ratio rear?
I will be installing my rebuilt 276ci FH in a couple weeks and was wondering if anyone is running a 3.25 rear with a 39 trans. I'd really like to be able to keep up with my buddies and their OD equipped cars. I currently have a 3.78 w/7.00X16 rear tires.
Gene |
03-13-2013, 10:51 AM | #2 |
Re: Anyone running a 3.25 ratio rear?
May work better for you with a bigger motor . With a stock 34 it is kinda poochy . The 67- input and cluster help with takeoff but you find yourself shifting more to make up for the wider gaps in the tranny ratios . Yes this isn't exactly what you asked but it is an example of 3.25 gears in a stock 34 . Won't do it again . 3.54'S!!!!!!!!!!!!!!!! Something that helps also is a pair of tall rear tires for extended trips . Easiest way to change rear gear anyway .
03-13-2013, 12:20 PM | #3 |
I have used 3.25:1 ratio in two cars with great success.. I also have used a C-4 automatic in that application. One is a 36 Ford Conv and the other is a 46 Ford conv.. The engine was a .080 over bore in both cases. Of course you aren't going to tear up tires at the stop light, but who wants to ruin good tires anyway.
03-13-2013, 12:49 PM | #4 |
It depends mainly on the weight and hp of the vehicle. A friend put 3.25 gears (replacing 4.11) in a light weight Track T roaster running a basically stock 8ba engine. This put his engine RPM right where he wanted it to be at 55 mph.
03-13-2013, 06:17 PM | #5 |
go with a 3:54, I currently have a 3:25 with a 51 Merc engine/77b isky cam in my 41 truck same 3 spd as yours and it is hard to get going on about any stoplight on a hill, have to slip the clutch, I am going back to the 3:54 but 3:25 will really make it run down the road!!!
03-13-2013, 08:17 PM | #6 |
Don't never get rid of nuthin! |
03-13-2013, 09:36 PM | #7 |
28 tooth car trans, there are actually two 29 tooth first gear cluster gears, pick-up and bus which is even lower-I have a set of those gears and first goes about ten feet , second goes about 20 more feet and then you are dead in the water for acceleration-but would pull a dead horses thru a key hole
03-14-2013, 08:44 AM | #8 | |
03-14-2013, 06:08 PM | #9 |
03-14-2013, 07:17 PM | #10 |
I own eleven horses. Buried a number through the years. Let me tell ya first hand, ain't no old flathead Ford gonna pull a horse through a key hole.
03-14-2013, 07:45 PM | #11 |
Got 3:26's behind a 239 in a 31 Pickup. Using a 29 tooth cluster in a 37 case. It works out real good for me.
Butch |
03-14-2013, 07:51 PM | #12 |
i have 3.25 in 46 convertible stock 8 ba runs great no problems with hills lots of model A'S running 327 in stock engins that work well here
03-14-2013, 08:02 PM | #13 |
Had a 3.25:1 9" rear in a '74 F100 w/3sp and 302..... it hauled pretty good! the 9" has some parasitic HP loss, but a built flatty like yours should be no problem to overcome that. However, the jumps in the 39 tranny gears may make a 3.54 better. crashbox 4sp w/3.25's is decent. A T5 w/ 3.54's is dang good. So, doing the mental math, I'd say 3.25's would be ok, except maybe on really big hills.
I'm just an old truck guy trapped in a hotrodder's world. |
03-14-2013, 09:04 PM | #14 |
I have several friends running 276 engines L-100 cams in heavy cars. these cars have 3.78 rear gears. However, they also have a Michael OD unit. now this puts the final drive into the mid 2.5/ 2.8 and yet they can drive very comfortably around in hi range. so I don't think a 3.27 would bother a well built engine, and give great economy.
03-15-2013, 07:09 AM | #15 |
Thanks for all the responses. I think I'll give it a try. i really would like a Mitchell but this would be much cheaper.
Gene |
03-15-2013, 07:35 AM | #16 |
I had one with a 8BA and a s10 5 speed. Worked fine but 1st gear in the s10 trans is 4 to 1 and taking off in second needed to slip the clutch alittle. 5th was great with the 325 rear. Can't say with a 39 box.
