03-11-2021, 02:58 PM | #1 |
Dead
Had the 40 running yesterday. Went out today to go for a ride (high 60's here and beautiful) Got a partial revolution. Then nothing. I don't believe the Bendix is jammed. Ck'd batt, it is 6.3 volts. Tried the button on the f/wall mounted solenoid. Again nothing. Didn't have time to t/shoot further.
Suggestions?? Paul in CT |
03-11-2021, 03:02 PM | #2 |
Re: Dead
Don't rule out a stuck Bendix. Put the trans in high gear and rock it back and forth. Hopefully that's the problem and not something more serious.
03-11-2021, 03:05 PM | #3 |
Re: Dead
If you have enough room and can get it moving you could try a roll start. If it starts let it run a while then cut it off and try with the starter again. In my experience the symptoms you are having are usually from a corroded or loose connection in the starting circuit somewhere.
03-11-2021, 03:08 PM | #4 |
Re: Dead
I agree with 51504bat above.
Also, at the battery, clean up the battery cable connections...
03-11-2021, 04:03 PM | #5 |
Re: Dead
If tat doesnt work , pull the plugs and try cranking .
03-11-2021, 04:16 PM | #6 | |
Re: Dead
Put your head lights on then once again use the push button under the solenoid. If the head lights dim that would be an indication the Bendix is bound up into the ring gear. Or there's a loose battery cable someplace. A bound up starter some times can be unlocked by rocking the car while its in gear but this takes a lot of physical force. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-11-2021, 09:31 PM | #7 |
Re: Dead
Hopefully not water in the cylinder like me....
"Came too close to dying to stop living now!" |
03-11-2021, 10:10 PM | #8 |
Re: Dead
No help from me... But I can relate.
I got no spark and can't figure out why? |
03-11-2021, 11:56 PM | #9 |
Re: Dead
Clean the battery connections and make sure they are tight, especially if this is first or second drive after sitting all winter. Moisture from the air seeps in and corrosion happens. Been there many times with vehicles and machinery that doesn't get used regularly. Or the battery just reached the end of the line. Good luck.
03-12-2021, 08:37 AM | #10 |
Re: Dead
All the batt connections are good/tight. Will try to get the wife to help "rock" it. Went thru the starter last year (long story).
Thanks guys. Keep 'em coming. Paul in CT |
03-12-2021, 09:00 AM | #11 |
Re: Dead
Someone mentioned the hydrolock, try pulling the plugs and spinning it if all else fails.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
03-12-2021, 02:43 PM | #12 |
Re: Dead
Wife and I rocked it back and forth as well as we couuld.
Still have 6.3 volts at the batt and to the sol. Everything else id dead, no lights, elec fuel pump, etc. Any new thoughts?? Paul in CT |
03-12-2021, 02:53 PM | #13 |
Re: Dead
Has to be dead battery or bad connections.
"whatever works!" |
03-12-2021, 02:55 PM | #14 |
Re: Dead
Did you actually remove and clean the battery cables and battery posts?
03-12-2021, 02:57 PM | #15 |
Re: Dead
Did you let the smoke out? Check out the wiring diagram for the model of 1940 you have on Mac Van Pelt's website and try checking the locations from the battery for power. It looks like the horns are on a different path from the solenoid than all the other electrics on the vehicle. Do the horns still work?
Good luck with your search. |
03-12-2021, 03:05 PM | #16 |
Re: Dead
If you can check the battery voltage while you try to crank it, or just turn on the headlights, I bet the battery drops to zero. If the battery voltage stays up, then has to be a bad connection.
"whatever works!" |
03-12-2021, 04:11 PM | #17 |
Re: Dead
The ground side of the circuit is just as important as the "Hot" side. Poor ground is like a dead battery. How old is the battery?
03-12-2021, 07:40 PM | #18 | |
Re: Dead
Paul is there an inline auto-fuse somewhere ? Curious how you make out. I do HVAC work and its not un-common to shut off an old service switch and when you "try" to turn it back on after a service no power. Sure enough a failed switch, something simple can give us fits. |
03-13-2021, 08:03 AM | #19 |
Re: Dead
A few years ago I took my dad's Model a to get a sticker and they told me to come back the next day. the next day the car would not start. Battery completely went in the course of 24 hours. It happens.
03-13-2021, 09:25 AM | #20 |
Re: Dead
as others have suggested a load test on battery
