Old 08-10-2018, 09:40 AM   #1
IndyA
Default Coil Voltage ???
While trying to isolate a motor problem in my '29 coupe, I dug into a box of parts that came with the car to get another coil to install... It was marked "12V"... put it on. Later resolved the problem (not the coil) ... Question.. can I keep this one on the car even though the car has the traditional 6 volts system ??... Thanks
IndyA is offline   Reply With Quote
Old 08-10-2018, 09:43 AM   #2
katy
katy's Avatar
Default Re: Coil Voltage ???
Check the resistance of the primary windings, it they are around 1.5 ohms you can use it with a 6 volt system.
Talk slow, think fast.
Old 08-10-2018, 10:05 AM   #3
IndyA
Katy... thanks for the fast response... do I put my multi-meter on the negative coil terminal and ground to test the resistance of the primary coil ???? IndyA
Old 08-10-2018, 01:23 PM   #4
California Travieso
Send a message via Yahoo to California Travieso
Katy . . . How do you test the secondary winding, and what is the value? I got a coil at a Swap Meet and Googled some articles on testing coils but they didn't give the values for either the primary or secondary windings.
David Serrano
California Travieso is offline   Reply With Quote
Old 08-10-2018, 07:34 PM   #5
40 Deluxe
Connect your ohm meter leads to the primary terminals, not ground. Disconnect the wires first.
Old 08-11-2018, 08:20 AM   #6
eagle
eagle's Avatar
If it throws a good spark it is just fine to use.
Old 08-11-2018, 08:53 AM   #7
katy
katy's Avatar
Ditto
Regarding the resistance of the primary windings,
6 volt coil should be aprox 1.5 ohms.
A 12 volt coil that uses an external "ballast resistor" is usually also around 1.5 to 1.7 ohms and will work fine on 6 volts.
Some 12 volt coils have a built-in resistor and are usually around 3 ohms.
Old 08-12-2018, 12:00 PM   #8
gustafson
Some say you should only use a performance coil. I am not one of them
gustafson is offline   Reply With Quote
Old 08-12-2018, 02:20 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
I don't remember ever hearing anybody say that a person should only use a performance coil . It is a matter of choice !!! Before trying the Pertronix flame thrower coil , I had never heard of anybody using one on their model A . The Pertronix flame thrower coils are offered in both 1.5 and 3 OHM like most other coils. I prefer the 3 OHM coil on 12 volts simply because it doesn't require the use of a ballast resister . Resisters don't look original on the model A and they get very hot.. I personally could care less what type coil that a person uses . Being my own man , I make my own choices . If the type coil that I use didn't preform flawlessly I wouldn't use it .
Purdy Swoft is online now   Reply With Quote
Old 08-12-2018, 03:35 PM   #10
2831As
Coils, brakes , FP regulators over and over. Whats wrong with stock
File Type: jpg 3A486BB2-1B02-4DEA-8B99-E4BB4CE55D43.jpg (26.0 KB, 9 views)
2831As is offline   Reply With Quote
Old 08-12-2018, 05:31 PM   #11
Purdy Swoft
Who said that anything was wrong with original model A coils . If in good condition original coils are probably better , stronger and of course prettier than most standard over the counter coils . I prefer performance coils on some of my cars . There is not necessarily anything wrong with original . Some are interested in upgrades. Some onlywant original for show purposes. A lot comes down to whether the car will be an ocaisional driver or a mostly
trailored show car . Its freedom of choice , if thats over your head , too bad !!!
PS If you pay close attention , you may learn something !!!
Old 08-12-2018, 07:43 PM   #12
gustafson
HaHa If everyone would pay close attention we would all learn something!!!
Old 08-12-2018, 08:19 PM   #13
Cape Codder
Cape Codder's Avatar
I have read that the Pertronix flame thrower coil or similar product which produces too much voltage, therefore, wearing the points much quicker than a regular Model A Coil. has anyone experienced this?
Cape Codder is offline   Reply With Quote
Old 08-12-2018, 08:47 PM   #14
gustafson
We have removed such coils here because of this issue, and cross firing between cyls due to excess voltage leak
Old 08-12-2018, 08:58 PM   #15
Purdy Swoft
The mention of 40.000 volts scares some people . I'm still running the same original style points that I got from Brattons in 06 when I installed the coil .
Old 08-12-2018, 09:30 PM   #16
29er
29er's Avatar
Roger that. I've got > 7,000 miles on my coupe with a Pertronix Flame Thrower 1.5 ohm coil and original points. "Power you can feel in the seat of your pants"!
29er is offline   Reply With Quote
Old 08-12-2018, 10:04 PM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, that's the exact experience a worker had at the yard where I worked. Someone wired the coil to the driver's seat spring, and the driver felt the power in the seat of his pants. True story.
Old 08-12-2018, 10:08 PM   #18
2831As
Sometimes when you wax your car it feels faster too.
Old 08-12-2018, 10:32 PM   #19
Mike V. Florida
Mike V. Florida's Avatar
The voltage and current at the points is the same no matter what coil or points you use if the resistance of the coil is about 1.5 ohms for 6 volt and about 3 for 12 volt. The 20 or 40.000 volts do not go through the points.
Old 08-13-2018, 12:38 PM   #20
Purdy Swoft
Thanks 29er for telling it like it is .The flame thrower coil gives power that a person can feel and we ain't talking about getting shocked . Some can't seem to understand this and it scares the hell out of them . The spark comes from the coil . Hotter spark in most cases increases power .
