09-20-2015, 06:39 PM | #1 |
Factory 4 speed on 31 Vicky ?
09-20-2015, 06:43 PM | #2 |
Re: Factory 4 speed on 31 Vicky ?
4 speeds were an option. They used AA 4 speeds
09-20-2015, 06:57 PM | #3 |
Something strange about the 4 Speed in photo #17....
09-20-2015, 06:59 PM | #4 |
Well, he had nice PICS!
Bill W.
09-20-2015, 07:00 PM | #5 |
Here is a photo the Factory 4-speed with an aluminum case??????
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
09-20-2015, 07:32 PM | #6 |
09-20-2015, 07:38 PM | #7 |
u r right Ron W. That IS a F150 RTS coupled to a AA Bell Housing.
09-20-2015, 07:57 PM | #8 |
Will the F150 RTS and AA bell housing fit right in as a bolt up?
Would the stock drive shaft and universal have to be modified? Is the F150 RTS forth gear an overdrive? Thanks for any info you can give me, I'd really appreciate the help. Al Leach |
09-20-2015, 09:53 PM | #9 |
Will the F150 RTS and AA bell housing fit right in as a bolt up?.....No
The bellhousing will bolt up to the flywheel housing. The F150 RTS will not bolt up to the bellhousing. Would the stock drive shaft and universal have to be modified? ...Drive shaft... Yes universal joint...No. Is the F150 RTS forth gear an overdrive?....Yes. Do a search of this subject. There have been many posts regarding it.
I noticed the harder I work the luckier I get! |
09-20-2015, 09:57 PM | #10 |
1930 roaster pick up here , came new with AA truck 4 speed , only one I have seen .
09-20-2015, 10:08 PM | #11 |
Doesn't look like my 4-speed....but it still may be a great driving car...it sure looks nice..
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
09-21-2015, 01:14 AM | #12 |
Ads like this make me want to ban, outlaw, and horsewhip car flippers!
09-21-2015, 07:32 AM | #13 |
Mag.
09-21-2015, 07:38 AM | #14 |
MAG. You are partially right and wrong. The F150 Aluminum Case is Redrilled and Tapped on the front to match the bolt holes in the AA Bell House (or an A BellHouse)- then four new 1/2" bolts are used to attach Trans Case to directly to BH.
As built from the factory not a direct bolt up - with new bolts holes drilled and tapped it is a direct bolt up. |
09-21-2015, 07:56 AM | #15 |
MAG,
Thanks for the direct answers to my questions. Looks like the Mitchell is really the best upgrade for the model A. Al |
09-21-2015, 07:59 AM | #16 |
There is some machine work required. I built my own. The gears are all syncro with overdrive in the box. The shifter is almost in original location. To me, it is the best driving of all the options available for the Model A. Ron W
09-21-2015, 09:16 AM | #17 |
Ken,
"Will the F150 RTS and AA bell housing fit right in as a bolt up?.....No" I chose this answer to the question because I did not want to mislead Al 29 Tudor into thinking this was a true "bolt up" installation. We both know the bolt pattern on the AA bellhousing is not the same pattern as the F150 and that, as you say, the F150 case must be drilled to match the AA bellhousing. And, in some instances, the throwout collar must be machined slightly to fit into the AA bellhousing. I should have been more specific and detailed in my first answer. Sorry,
09-21-2015, 09:34 AM | #18 |
by the looks of that rear adpt. conversion by modelaonly here in calif.
09-21-2015, 09:38 AM | #19 |
I suspect a third party did the posting who is not Model A certified.
Oklahoma City Model A Restorers Group. |
09-21-2015, 11:08 AM | #20 |
It should probably be mentioned that "Bolt on" kits are available from suppliers who have done all the "magical" machine work. Ron W
