09-18-2015, 09:17 PM | #1 |
Door window replacement on coupe
Was down to my favorite glass shop getting a new glass for the roll up rear in the coupe and a side window behind the driver. We did the flame test and the double reflection was on every window. I know the back roll up was single thickness and so was one side window so we took the other side out and pealed off the rubber. Single thickness, just plate glass. Went to the passenger door and looked at it from above, no tell-tail line so we did the clink test and the flame, double image.
So now I am going to replace the door glass and need your assistance in how to remove it safely? I know I could shatter it and clean up the broken bits but I'd like to use it for a pattern, besides I always end up bleeding if I break glass, even when done on purpose and carefully. So how do you remove door glass on a coupe? The bar in the middle of the door is riveted in place on both top and bottom. As always, thanks in advance for you replies. |
09-18-2015, 09:52 PM | #2 |
Re: Door window replacement on coupe
Dave,
Isn't there a removable plate on the top of the door, to let it come out the top??? Bill W.
09-18-2015, 10:41 PM | #3 |
