09-16-2015, 10:42 PM | #1 |
How do you tell original hood latches?
I'll be at a swap meet this weekend. I would like to know how to tell an original hood latch specifically 1931 if there's a difference in '30 and '31. I've done a search but most threads were how to restore latches.
I've always thought the repro latches had a smaller diameter shaft whereas the originals were noticeably larger. There has to be other differences that I'm missing. Up til now I've only looked for the thicker shaft and 2 tabs rather than 3 to fasten them down. Thanks in advance |
09-16-2015, 11:44 PM | #2 |
Re: How do you tell original hood latches?
Repro latches have a sharp flat hook. That is the corners are a sharp 90* that doesn't fit the hood pockets as well as an original. I posted pictures of a repro latch a year or two ago. They just don't have a quality look, and as you said the shaft is thinner.
09-17-2015, 02:17 AM | #3 |
Barb
I will see you there and show you what to look for. I will bring the floor pan with. John |
09-17-2015, 12:48 PM | #4 |
Does anyone, on here, remember when The Ford Motor Company reproduced the original hood latches, back in the 60s ?
Would they pass as genuine ? MIKE : (mikeburch) |
09-17-2015, 06:10 PM | #5 |
Mike the later so called reproduction ford latches were used to hold down battery box covers on ford big Trucks for many years.and they only made they with the three ears. if you compare the hooks they are a little shorter and a little different shape than the original Model A latches.
09-17-2015, 07:38 PM | #6 |
Take an original with you and compare. Once you see it then you know. |
09-18-2015, 12:57 PM | #7 | |
It is interesting that FORD gave them the "A" prefix part number. You can see it on the tag. MIKE (mikeburch) |
