09-20-2015, 04:13 PM | #1 |
Turn signal flasher
I installed turn signals 4 years ago and never have had a problem until lately. I'm running 6 volts with a 900 signalstat. The problem is some times and it's getting more often, the flasher doesn't flash but a couple times and then just stays lite up on the signalstatt and also the turn signal light. If this is the flasher unit going bad what NAPA number would I ask for? I'm running non LED's.
09-20-2015, 04:51 PM | #2 |
Re: Turn signal flasher
Flashers are cheap, drive the car to the part shop, pull the flasher and buy a new matching unit.
Or you may have a bad ground.
09-20-2015, 05:03 PM | #3 |
Yep, what Burner31 said. Its easy to remove the old flasher and see what number it is. It is probably a 535 [ 3 prong]. New ones however can sometimes be junk and old originals are usually the best quality.
09-20-2015, 07:11 PM | #4 |
