Old 09-17-2015, 09:43 AM   #1
mrraford
Default Hubcaps and how to fit them
It has been too long since I mounted the hubcaps on the pickup truck and I just can't remember the technique.
I'm attempting to mount the hubcaps on wheels for the 68C and it just isn't working. Anyone want to share a tried and true method of getting a centered snug fit?
Also, several years ago one of our now defunct club members showed up with a tool purported to do a good job of bending the tabs on hubcaps so that they could be snapped on and off without damage. Anyone have experience with this tool and do they still sell them?
mrraford is offline   Reply With Quote
Old 09-17-2015, 10:08 AM   #2
CarlG
CarlG's Avatar
Default Re: Hubcaps and how to fit them
I haven't used one, but the vendors do have them. See them advertised in the national magazines all the time. (for 30-31 only)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-17-2015, 10:31 AM   #3
Fullraceflathead
Fullraceflathead's Avatar
We need one for the '28 - '29 style though.
As far as I know this tool does not exist.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-17-2015, 04:34 PM   #4
160B
160B's Avatar
My method on 1930, 31 hub caps, and I find it easy and successful, IMHO.
I have used this method on three different vehicles.
I use an adhesive backed weather stripping that I cut a short section and attach to every other tang of the hubcap on the side of the tang that will contact the rim. I place the hubcap on the rim and lay the rim on a piece of carpet hubcap side down. I then take a screw driver or a Model A ford tire iron and bend the tabs down, then using a hammer and the screwdriver or tire iron seat the tab tight to the rim. Start on one side and then do the one on the opposite side and then move 90 degrees and repeat until the tabs with the weather stripping are bent down. Check the cap for tightness and hammer any loose tabs and you are done.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 09-19-2015, 09:15 PM   #5
Dick Deegan
Dick Deegan's Avatar
I use this tool for the hubcaps on my 1930 coupe and it works great. I haven't lost a hubcap yet using this method. It also allows you to remove the hubcap easily and adjust wheel bearings, tighten rear wheel axle nuts etc. and then to easily replace the hubcap.
Dick Deegan is offline   Reply With Quote
