02-22-2012, 04:46 AM
#11
Re: Ah Ha! I'm Brilliant!
Originally Posted by Roadster62
Hood hinge rod removal with an electric drill works well. Lube up the hinge with your favorite penetrating oil let sit overnight. Tap the rod out an inch or so, attach the drill to it. Once you get it spin just put some pressure on it and it will pull out.
I use wood dowels for hinge pins, plenty strong.
I dab the ends with Magic Marker, soak them in linseed oil and NO MORE RUST OR CREEKING Cheap too. Bill W.
"THE ASSISTANT GURU OF STUFF"
