05-06-2020, 08:01 PM | #21 |
Re: Question: 1940 Ford Radiators.
The radiator in my 39 Zephyr isn’t a pressure system either. The water pump guy ( Skip Haney ) sells a 4 pound pressure relief that clamps to the end of the overflow tube and that’s what I put on my Zephyr. Works great.
05-06-2020, 11:22 PM | #22 | |
For whatever it's worth, here are a couple of pics that I ran across. The first is a "91A-8005" '39 and '40 PASSENGER CAR radiator. The second is an "11A-8005" '41 PASSENGER radiator... ..FWIW! DD . |
05-07-2020, 02:13 AM | #23 |
A girl once told me I was tall. What she really meant was she thought i was skinny.
Alan |
05-07-2020, 06:53 AM | #24 |
I think Kube might be missing the fact that this is a 41 pickup truck. Which, in my experience has the same radiator as the 40. I know I took the radiator from my 41 pickup and used it in my 40 sedan for some time.
05-07-2020, 07:49 AM | #25 | |
Okay, here we go: The '39 dlx, '40 passenger and light truck and '41 light truck used the same (91A) radiator. The '41 passenger cars used a DIFFERENT (11A) radiator. I apologize if this caused any issues. None of the aforementioned radiators were pressurized when they left the assembly line.
05-07-2020, 08:24 AM | #26 |
I think that is why it is balooning up and causing the split. Mart. |
05-07-2020, 08:49 AM | #27 | |
05-07-2020, 10:11 AM | #28 |
Kube,
Will the 91A tank fit on a 41 radiator? |
05-07-2020, 02:17 PM | #29 |
I put a new radiator in my 40 Coupe last year . It has the 91 stamped in the top tank and the height is just like the 39-40 but the cap is located in the center and is set up for a pressure cap . The Green Book says it’s a service replacement.
05-07-2020, 03:49 PM | #30 | |
Ken....Is it stamped "91A-", or "91C-"? The literature I have shows that all the pick-ups through at least '52 as having the fill cap opening in the center of the top tank. DD |
05-07-2020, 04:28 PM | #31 |
That would be correct. And usually, the replacement is not split core.
05-07-2020, 04:29 PM | #32 |
Couldn't tell ya. I doubt it...
05-12-2020, 06:42 AM | #33 | |
Thanks again. To update on my situation and the reason I asked the question in the first place, My tank is balooning out due to excess pressure. I have a 4lb cap but I think it is too long and is overpressuring the radiator. I will try another new cap and will repair the tank. I will add two cross braces to resist outward movement of the top tank sides. I'm waiting for some parts to arrive so I can do the job. I think it will be ok if the pressure is genuinely held at 4 lbs and the cross braces will help. I'll make a little video showing what I did. Cheers! Mart. |
05-12-2020, 09:49 AM | #34 |
cancel post.
05-13-2020, 06:54 AM | #35 |
1940 60HP radiator.
05-13-2020, 07:02 AM | #36 |
That's interesting, never seen one like that. Can anyone tell me if that thick-ish pad on the mounting foot in the last pic is standard, and if a 85hp would have had that?
Mart. |
05-13-2020, 07:24 AM | #37 | |
Ken |
05-13-2020, 08:56 AM | #38 |
Kube?
05-13-2020, 09:37 AM | #39 |
05-13-2020, 12:12 PM | #40 |
See post 37. I've never seen that setup
