01-06-2019, 12:03 PM | #1 |
1929 transmision
ok guys, when I get to thinking about things , I usually get into trouble! I rebuilt the transmission in my 1929 two door sedan a year ago & it has not been right sense! I have read about getting new but bad main shaft & cluster bearings! thinking about going back it to see if this is the case. hear is where it gets dangerous! I am wondering if it is possible to either put 32 or later gears in my case, so it would have synchronized gears? or can I possibly use a complete later model transmission in it! can it be done & what will I get into if I try this?
01-06-2019, 12:33 PM | #2 |
Re: 1929 transmision
If I remember right ford did not g synchro until 39. And that would require a totally different case.
Mike
01-06-2019, 04:26 PM | #3 |
A synchro trans is available from vendors if you must have synchros. What problems are you having with your existing box?
01-06-2019, 04:52 PM | #4 |
I don't believe you can install later model synchro parts in the A box. Ford's first synchro started in '32 [from what I remember] with changes until '39 which is the preferred early box. And there are adapters available to install these transmissions.
01-06-2019, 05:57 PM | #5 |
I got it all back together & I ended up with a little noise in first gear, I can live wit that. you go to second gear & I have a little more noise, not bad until you let off the gas & then it sounds like there is sort of a grinding, as best as I can explain it! then you go to third & all noise seems to go away. I realize it is not going to be as quiet as a new burg warner, pardon the spelling, but it just is not right.
01-06-2019, 06:07 PM | #6 |
01-06-2019, 07:05 PM | #7 |
There is a written value for cluster gear clearance in the transmission case that you can check with a feeler gauge. Noise in first and second are to be expected. How well does it shift?
01-06-2019, 08:21 PM | #8 |
You did not stste what parts you used for the rebuild. Did you use your original parts or reproduction gears, bearings and shafts ?
01-06-2019, 08:22 PM | #9 |
Have you checked out Tom Endy's articles??
http://www.santaanitaas.org/wp-conte...sion-Traps.pdf https://www.santaanitaas.org/wp-cont...ugust-2018.pdf Bob |
01-07-2019, 09:25 AM | #10 |
01-07-2019, 10:10 AM | #11 |
01-07-2019, 11:04 AM | #12 | |
01-08-2019, 06:57 AM | #13 | |
well at those kind of prices it looks like i will just be repairing what i have again! That is a bit salty for me. I will post what ever i find a little later! |
01-08-2019, 11:40 AM | #14 |
The Mitchell looks like the original because it is, with the insides all new Mitchell made gears and Ford synchronizers. There are choices of stock first and second or 15% more speed in first and second. I live where it is mostly flat and the latter works well for me. When I'm in the hills I'm usually already traveling toward 55 mph or so and with the Mitchell O/D I can split the gears and maintain a goodly pace. No one would know that it is a Mitchell transmission unless they notice that when I shift it is not necessary to double clutch and the shift pattern is tighter, not so much travel from first to second, etc. Works for me, and the bride can drive it home if I keel over. Can do similar with a 39 box but it does look out of place to the trained eye. Works well though, I have had a few.
01-08-2019, 12:36 PM | #15 |
The Clings kit in a very professional solution. The $1000 figure includes your expense for the 39 tranny. If you already have the early Ford transmission. You can take 500 off that $1000 figure.
I already had the v8 trans, so I only needed the Clings kit. Think it was about $450. I, and everyone who has driven my truck loves it. No clugy stuff, very well engineered! The only thing that gives the modification away from on top, is the shift tower is 1 inch forward of the A tower. Pedals are in the exact same place. |
01-08-2019, 12:54 PM | #16 | |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
