04-16-2014, 07:27 PM | #1 |
1940 ford sun visors frames
I need to know what is the correct color for the1940 coupe sun visors frames , anyone know . Thanks
04-16-2014, 08:28 PM | #2 |
Re: 1940 ford sun visors frames
Brooks
Run that by Kube, he is the expert on 39, 40 Ford. Bruce Works good Lasts long time |
04-18-2014, 07:23 PM | #3 |
Brooks
I am sorry no one was willing to help you. Here is a link to the premium supplier of upholstery for classic cars. Welcome to the Ford barn Bruce Works good Lasts long time www.lebaronbonney.com |
04-19-2014, 05:42 AM | #4 |
Std or Dlx?
04-19-2014, 09:43 AM | #5 |
Mine are original and seem to be the same color as the headliner. Sorry I don't know the actual color, it looks like beige, but I'm sure Lebaron Bonney can help you.
04-19-2014, 01:10 PM | #6 |
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. |
04-19-2014, 07:58 PM | #7 |
On the 40 Ford the sun visor the metal frames are covered by the headliner cloth. The DeLuxe has two visors. The Standard had only one. The only metal part that shows is the mounting bracket and a small part of the steel rod that through the visor. I painted mine the same color as the rear view mirror. Don't know if its the OEM correct color. On page 3-2 of the 1940 FORD Book:A Compendium of Current Restoration Practices published in 1987 by the EarlyFORD V-8 Club of America, it says that "the metal rod and its mounting piece are painted medium brown."These photos were taken with a flash.
04-19-2014, 08:00 PM | #8 |
John, I am taking about the metal frame that has the three screw that holed them to the car. What color is this frame on a deluxe coupe
04-19-2014, 08:04 PM | #9 |
Thanks,19fordy the metal frame is what I wanted to know the correct color. Thanks every one! Brooks
04-19-2014, 08:24 PM | #10 |
Brooks, I am not 100% sure that is the correct color, although I vaguely remember it being that same color when I first took it all apart in 1973.
04-20-2014, 01:57 PM | #11 |
I misunderstood the question. It looks to me like the visor brackets and frame are the same color as the rear view mirror, which is a medium brown. Mike Kubarth will know the exact color. Post the question on the Early Ford V8 forum under the 40 Ford Book forum.
04-20-2014, 10:46 PM | #12 |
The ones I've seen are low gloss to no gloss medium brown
