08-10-2019, 08:48 AM | #1 |
Looking for exploded view of 31 locking door handle.
In particular, which end of the plunger that is operated buy the tumbler go up.
It appears it can go either way, but I want to be sure before I assemble everything. Thanks in advance, Don |
08-10-2019, 10:32 AM | #2 |
Re: Looking for exploded view of 31 locking door handle.
are u looking for the cam position?
www.whidbeymodelaclub.com |
08-10-2019, 05:27 PM | #3 |
Thanks Gary, that is also helpful, but to be more specific, when you turn the lock with a key, that little nub on the end of the lock clyinder pushes a square pin up and down. The pin is what I am unsure about installing.
Thanks again, Don |
08-11-2019, 06:22 AM | #4 |
How do you get the cylinder out of the handle.?
08-11-2019, 03:27 PM | #5 |
Read this,thanks to supplier of info. Restorer M/J 1992 pg 32
08-11-2019, 03:45 PM | #6 |
Thanks again, Don |
08-11-2019, 09:08 PM | #7 |
that is NOT a 31 handle, it is a 30 or earlier. the 31 have a notch in the face for the release. it is called a removable cylinder. before that you had to take the handle apart to remove the cylinder.
