Old 06-07-2010, 02:13 PM   #1
A-Jay
A-Jay's Avatar
Default Moto Meter won't fit new Radiator ?
I just installed a new Brassworks Radiator 10 fins per in the Model A and tried to install the Moto Meter and it will not fit ? any advice on the fix. What needs to be trimed or cut. Thanks for you replys.
A-Jay is offline   Reply With Quote
Old 06-07-2010, 02:17 PM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: Moto Meter won't fit new Radiator ?
Originally Posted by A-Jay View Post
I just installed a new Brassworks Radiator 10 fins per in the Model A and tried to install the Moto Meter and it will not fit ? any advice on the fix. What needs to be trimmed or cut. Thanks for you reply's.
CALL THEM, before you trim and void any warranty, it is suppose to fit?
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-07-2010, 11:51 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
AGREED, call them. For the money they get it should work perfectly!!!
Old 06-08-2010, 12:54 AM   #4
pat in Santa Cruz
pat in Santa Cruz's Avatar
I recently tried to put a locking cap quail on a new radiator from Brattons. It did not fit . The I.D of the neck is smaller than the O.D of the cap. I had to trim the bosses that hold the brass tabs so it would slip past the top of the neck where the gasket seats.I had to grind the outside edge of each tab boss about .040.
pat in Santa Cruz is offline   Reply With Quote
Old 06-08-2010, 12:55 AM   #5
Grampy
Does your Motometer have adjustable tabs to secure it to the radiator neck and the meter rotates to flip back for access to the radiator neck.
Check for the tabs and loosen with the allen wrench, position the cap and meter correctly, tighten the tabs.
If this is not the solution, let me emphasize the previous responses - Don't cut, file, or change anything without talking to Brassworks. They make a quality product and I'm sure the answer is elsewhere.
Hope this helps,
Steve
Grampy is offline   Reply With Quote
Old 06-08-2010, 06:09 AM   #6
allen
allen's Avatar
Send a message via ICQ to allen
mine was loose fit when going down the road, Install thicker gasket or oring, is this the fitting problem or will not go on at all
allen is offline   Reply With Quote
Old 06-08-2010, 06:14 AM   #7
Bob A.
Now that you mentioned this, I do remember doing something with a quail or motometer. I think there was instructions that came with the moto- meter for just this problem. I would definitely not modifier the radiator neck or tabs. Old age must be setting in just can't remember! I guess this doesn't help very much.
"Some Talk the Walk while others Walk the Walk"
Bob A. is offline   Reply With Quote
Old 06-08-2010, 06:22 AM   #8
Bob A.
Also I guess I can't remember how to spell /type anymore "modify"
Old 06-08-2010, 06:27 AM   #9
Bruce Adams
Bruce Adams's Avatar
Does the new radiator's OVERFLOW TUBE stick up too much. If so, it can be bent out of the way it is just a copper tube.
I did that on a new Bratton's HD radiator 1930-1931 to fit a thermo quail.
Bruce Adams is offline   Reply With Quote
