10-18-2011, 08:57 AM | #1 |
1932 Ford 5W Hiboy Project
City:
Toronto
State:
Ontario
Price:
$15,500
1932 Ford Coupe Option #1
-Fiberglass Body 2.5 Chop 40 Ford F/G dash & Model A Style Dash -New Fiberglass 5 Piece Garnish Molding Set -need to be chopped -New Steel Grille Shell with New Stainless Grille Insert w/Crank Hole -New Aluminum Rad for SBC with Transmission Cooler -New Steel Vintiques Gas Tank -New Hidden Door Hinges & Trunk Hinges -need to be installed -New Complete Street Rod Wiring Harness -needs to be installed -Hotrod Bench Seat in Black Leather -Original Front Window with Hinges -needs chopped -350 SBC Low Km Rebuild with Mild Cam -New Aluminum Finned Valve Covers -New Sanderson Lakester Ceramic Coated Headers -Offy Vintage 3 Deuce Intake with Ford/Holley Carbs -New Air Cleaners & Rebuild kits for Carbs -Eelco Progressive Linkage, New Aluminum Fuel Block -350 Turbo Transmission Rebuilt with Mild Shift Kit -New Lokar 23 Nostalgia Shifter with Boot -Ford 8.8 Drum Brake Rearend Rebuilt -New 15x5.5 Front Wheels with 165R15 BFG Radial WWW Tires -New 15x8 Rear Wheels with 285/70R15 BFG radial WWW Tires -New 41 Ford Hubcaps & Ribbed Trim Rings -New Fully Boxed Chassis with Tubular Center Section Bolt-in Transmission Mount, Model A Front Crossmember Vega Steering Box with Pitman, Front Panhard Bar, Draglink, Tie Rods & Bolt-on Brake Pedal Assembly, Steering Arms -Stainless Spreader Bars, Front License Mount, 39 Ford T-lights -New Complete Big Ford Front Disc Brake Kit, 46 Ford Spindles -Superbell 4 Drop I-Beam Front Axle, Posie Front Drop Spring -S/S Adjustable Spring Perches, S/S Upper/Lower Shock Mounts -S/S Headlight Mounts to Upper Shock Mount,New Short Shocks -40 Ford Radius Rod Arms split with Rod Ends, New Kingpin Kit -New BLC 682 Style Headlights with Turn Signals on Top -New Rear Coil-Over Carrera/QA1 Shocks -New 4-Link Set-up With Clevis & Rod Ends with Panhard Bar -SBC Points Distributor with Pertronix Igniter Kit -New Red Cap, Rotor, Wires, Vacuum Lines Etc. -Ontario Ownership/Title $15,500.00 Rolling Chassis Option #2 Everything Listed Above Including Headers & 3-Deuce Intake But Without the Following: - No Engine, No Transmission, No Shifter & No Wiring Harness $13,000.00 NO TRADES PLEASE |
10-18-2011, 08:15 PM | #2 |
Re: 1932 Ford 5W Hiboy Project
Are the doors inner and outer together? Please Email me at [email protected] and a phone number. Thanks, Larry
10-19-2011, 02:57 PM | #3 |
no, the doors & trunklid are in 2 pieces.you hinge the inner panels & get everything working then fiberglass the outers to get all the gaps pretty close & then sand/grind them.i am told this is the better way because of more room for errors. i did a 32 roadster this way before & it worked great because the inner piece has to clear the jambs & sill area without rubbing when closing the door.plus it's easier then trying to work inside a door with my sausage fingers.
thanks dave 905-561-0114 |
10-20-2011, 04:53 PM | #4 |
Thanks Dave |
