02-16-2021, 10:25 AM | #21 |
Re: Loosen / tighten individual cylinder head nuts?
Normal is relative. It's not normal, but it's quite common. There is no oil supply on this side, so it can only be a mixture of soot and water. (I have too.) If there are only 1-2 drops, I'd just watch it first. If it gets stronger and you can see that the cylinder is pulling water, (you can see the spark plug and the piston surface) then you have to intervene and replace the cylinder head gasket. In addition, I think I have read somewhere that you should check new cylinder head gaskets and check the nuts more often. Tighten again and again with the torque wrench because the seal is still sitting and still working due to the different temperatures. By the way, my head gasket didn't leak after the action than before. Greetings Andy
02-16-2021, 11:15 AM | #22 |
Wow, really nice installation, very clean. I have a couple of comments:
The engine flexes a small amount. I would have added short lengths of rubber hose near the firewall. There are some really strong magnets available, 30 pounds pull. Using these would mean that you would not have to disturb the head nuts and that the system would be easy to remove if desired. I see you have a valve at the return. This is a very good idea as eventually we may have a summer. Did you build a scoop at the inlet to the heater system (water outlet)? That makes the system run when the thermostat opens up.
02-16-2021, 11:30 AM | #23 |
It is hard to see in the pictures, but the pipes have 3mm clearance on all sides in the bulkhead and can move. The transition to the heat exchanger is then built with rubber hoses. I would not like a solution with magnets. The super magnets did not yet exist in 1930. But that would be a solution that could have been built back then. I haven't made any changes to the thermostat housing and it has always been warm enough. Even with the thermostat open. The only thing I still need is either a 6V motor for the blower, or a voltage converter. A 12V motor is currently installed, which runs quite slowly with the 6V in the car. It could get warm faster ...
02-16-2021, 11:53 AM | #24 |
Suggest that you measure how much current (amps) the motor uses on 12 volts and then get a 6 volt to 12 volt convertor that can handle the current required plus about 20-25% (or more).
02-16-2021, 12:57 PM | #25 |
Yes, that's my plan too (parts are already here.) ... At least it's plan B. Plan A would be an original 6V engine. But it's hard to find.
02-16-2021, 01:21 PM | #26 |
I think you have thought of everything for the installation of your heater. Good luck finding the 6 volt fan motor. Another option would be a 6 volt to 12 volt converter or carrying around a small 12 volt battery.
02-16-2021, 02:08 PM | #27 |
Ah, thanks for the hint. I once bought a set with many seals and this rubber was included. But I never found out where it belonged. I can retrofit it now.
02-16-2021, 02:09 PM | #28 |
Good afternoon...check Speedway Motors...I was able to purchase a six volt motor that was part of a six volt radiator fan system...it was pretty reasonable...Ernie in Arizona
02-16-2021, 02:31 PM | #29 | |
02-16-2021, 03:13 PM | #30 |
I have replied to your PM.
02-16-2021, 03:16 PM | #31 |
I very well executed installation but one thing jumped out at me. Why did you insulate the return pipe?
02-17-2021, 02:13 AM | #32 |
Because you could burn yourself if you touch it. No not true. The isolation is actually for optical purposes only. It looks more appealing, and you don't see that it is pipes and fittings from the heating industry.
02-17-2021, 04:16 PM | #33 | |
02-18-2021, 11:06 AM | #34 |
Larry Brumfield and others recommend re-torque sequence with engine warm, then completely cooled off followed by backing off nuts no more than 1/8th turn, one at a time before setting torque.
