Old 05-17-2018, 03:31 PM   #1
37Flat
37Flat's Avatar
Default Stiff Clutch Release
Just finished rebuilding the transmission and everything works fine - until I installed the Clutch Release Shaft. New Bushings went in smoothly, but when I went to put the new Shaft in I had to lightly tap it into place. It's so stiff that the Throw-out Bearing Spring can't bring it back into place. The Arm 7511 will also have to be tapped into place, so I'm thinking it's the Shaft, not the Bushings.
Is this normal for these new parts (Mac's)? Is this something that will break in, or something I have to fix or return to the seller?
Any ideas would be appreciated. Thought I was down to the easy part.
Chris
KNKStudio221.com
37Flat is offline   Reply With Quote
Old 05-17-2018, 03:50 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Stiff Clutch Release
A lot of the pressed in bearings require sizing with an appropriate reamer. A lot just depends on how tight the clearances are. If you got it in there at all then it's close. It may only need another .001" out of them. A lot of folks aren't fans of the adjustable reamers but there are other alternatives. You might be able to lap them in but make sure you remove all the abrasive as best you can.
Old 05-17-2018, 04:00 PM   #3
Capsacto
Capsacto's Avatar
I had the same issue when rebuilding my 37 tranny. I honed those bushings with an old brake cylinder hone. Leave the bushings in the trans. Hone them very slowly and gently, until the shaft goes in by hand. Put a little grease on the shaft, install it, and then squirt some grease in the two zerk fittings while the trans is still out.
Ed
"I find that the harder I work, the more luck I seem to have."
- Thomas Jefferson
Capsacto is offline   Reply With Quote
Old 05-17-2018, 04:12 PM   #4
37Flat
37Flat's Avatar
Thanks to you both. Sometimes I just need to be pointed in the right direction.
Chris
KNKStudio221.com
Old 05-17-2018, 07:15 PM   #5
cas3
you need some of this stuff, time saver. invented by the navy for fitting propeller shafts thru the hull. mix with oil, and it only eats until there is clearance, then will stop and you just wipe it off. wont stay abrasive like valve lapping compound. https://www.newmantools.com/lapping/time.htm
Thread Tools
Display Modes
