Old 07-14-2017, 06:28 AM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 39 Ford Clutch Throw Out Hub.
What sort of interference fit should there be between the clutch throw out hub and the fitted throw out bearing.
Suspect my almost slide on fit with a new bearing suggests too much wear at hub locating surface. Time for a new Hub?
Appreciate assistance.
Phil NZ
Phil Gillespie is online now   Reply With Quote
Old 07-14-2017, 06:35 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 39 Ford Clutch Throw Out Hub.
It is a snug fit. Can be slight press or need to hammer to tap the hub in place. Not a slide fit.
Old 07-14-2017, 01:12 PM   #3
KiWinUS
KiWinUS's Avatar
Green sleeve retaining Loctite is your friend Phil
Cheers
Tony
Old 07-14-2017, 01:56 PM   #4
Kube
Kube's Avatar
Phil NZ
Phil,
Those hubs were not machined for an interference fit. Rather, they were machined for a match fit. I'd suggest you measure both the hub O.D. and the bearing I.D. accurately and see what you have.
I'd be satisfied with no more than .001" wear on the hub.
Old 07-14-2017, 03:47 PM   #5
Phil Gillespie
Thanks for that info.
Will check measurements. But with items apart seem a little too easy to fit on
Will maybe go for the loctite. Is this the same which can be used for the clutch plate securing screws? Or to just use new ones with spring washers?
Appreciated
Phil NZ
Old 07-14-2017, 03:59 PM   #6
Kube
Kube's Avatar
Appreciated
Phil NZ
New split type lock washers are all that are needed for the clutch plate.
Locktite is okay in many applications but was never intended to fill voids.
Of course it's up to you which direction you'll take but me? - given the labor involved to replace that hub later, now may be the time to skip the easy route and do it properly.
Old 07-14-2017, 04:43 PM   #7
Phil Gillespie
Yes you are right, Kube, as already missed out replacing the clutch plate and only did clutch disc and bearings. And now need to do the clutch plate as some slipping was still occuring. Thought plate looked ok but it should have been checked properly with spring tensions etc. Always a learning curve there some where. At low load was ok but not high load. Idling: 810 lbs. 6000 rrpm:1685. So if springs not right wont get the 1685 at high load which i believe is what i was experiencing.
These Ford Service Bullitens have all this useful info.
As they say do it right first time and do it correct.
Thanks,
Phil NZ
Old 07-14-2017, 05:19 PM   #8
Kube
Kube's Avatar
Thanks,
Phil NZ
Phil, This SO reminds me of when I had my repair shop. That was in the early 70's through the 80's. A number of folks would come to me for a clutch replacement and insist I only replace the disc. I would always and sternly advise them that this was a BAD idea as sooner, rather than later, either the plate and / or the bearing would fail.
There was NEVER a time when my advice did not prove to be 100% correct.
It wasn't a big deal to me as I got paid to replace the clutch again.
Sure, I felt bad for the clients but always felt I did my best to offer the initial advice.
Old 07-14-2017, 05:54 PM   #9
Capsacto
Capsacto's Avatar
Phil, don't forget to replace the pilot bearing/bushing while you're in there.
Ed
"I find that the harder I work, the more luck I seem to have."
- Thomas Jefferson
Capsacto is offline   Reply With Quote
Old 07-14-2017, 07:32 PM   #10
Clem Clement
Clem Clement's Avatar
My late uncle taught me to replace all four items: clutch, pressure plate, TO bearing and pilot bearing.
Clem Clement is offline   Reply With Quote
Old 07-14-2017, 09:02 PM   #11
Kube
Kube's Avatar
He was in my opinion 100% correct.
Old 07-14-2017, 09:15 PM   #12
Phil Gillespie
Yep thats the plan. 4 items to be attended to.!! Now just awaiting parts.
The clutch plate has the orange coloured springs but unless tested hard to tell by observation and just by pushing down on the 3 fingers.
At least this time came apart smoothly, rolled the rear end back, leaving brake line in tack as enough movement for this. Wheels off and rolled on rims only.
Phil NZ
Old 07-14-2017, 11:29 PM   #13
GB SISSON
GB SISSON's Avatar
I just slid my new TO bearing on about two hours ago. And yes I see it slid on a bit too easily. Thanks to this post I will check a couple more I have around the shop, and hope for a tap on fit. Thanks!
'47 1/2 ton pickup next project, '47 one ton panel 99% stock nearing completion, '47 2 ton with 8ba and 9' script stakebed, '46 1/2 ton woodie project,'59 F350 9' flareside pickup with cummins 6at. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 07-15-2017, 03:44 AM   #14
Phil Gillespie
Thats what i would expect also a light tap on fit as opposed to an easy slide on or press fit.
Phil NZ
Thread Tools
Display Modes
