Old 04-18-2018, 01:52 PM   #1
jhowes
Default Paint and e-brake boot
My 31 2-door has the top down to the belt line painted black. The body color continues down from there. On the inside the windshield posts are black as is the dash rail and gas tank. Is this right or should the inside be the lower body color? Second question; how do you guys get the e-brake boot off of the handle? Mine is very tight at the top and seems to tight to be removed without it splitting. Jack
jhowes is offline   Reply With Quote
Old 04-18-2018, 02:56 PM   #2
Will N
Will N's Avatar
Default Re: Paint and e-brake boot
I'm pretty sure the dash rail and gas tank should be lower body color. The inside and outside of the windshield posts are upper body color. Originally, there was no boot on the e-brake (or shifter).
Will N is offline   Reply With Quote
Old 04-18-2018, 03:10 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
I use Vaseline but if the boot is old and dry it may split anyway.
Old 04-18-2018, 03:25 PM   #4
fordfixer
Heat it up with a hair dryer. That soften it and let it stretch.
fordfixer is offline   Reply With Quote
