07-24-2019, 09:04 PM | #1 |
Oil pressure
Drove to Duece days in Victoria BC, oil pressure good came home after dark oil pressure 0 on the gauge, made it home no noises, how do I check the sending unit? gauge?Oh ya 40 Merc
help Last edited by nesloyrag77; 07-24-2019 at 09:05 PM. Reason: for got car |
07-24-2019, 09:35 PM | #2 |
Re: Oil pressure
sounds like electrical (come home after dark)
07-24-2019, 09:37 PM | #3 |
Re: Oil pressure
Try a mechanical to test. If mechanical is fine, then track it through electrical. A cheap mechanical can bought most anywhere and are fairly accurate.
07-24-2019, 09:56 PM | #4 |
Re: Oil pressure
You can check the gauge with a 1 1/2 v battery. There are check procedures in previous post. But, as Tinker posted, I would install a mech gauge to be sure what the engine oil pressure is first.
07-25-2019, 07:29 PM | #5 |
Re: Oil pressure
found the problem the sensor was bad, what a challenge to get it out, had to cut and weld up 2 wrenches to get that stupid thing out, grounded the sensor gauge went to high oil pressure, new sensor coming
07-25-2019, 09:30 PM | #6 |
Re: Oil pressure
Personally I like to put a mechanical on to test out the electric gauges anyway. . |
07-26-2019, 10:12 AM | #7 |
Re: Oil pressure
With no oil pressure, the engine will seize up in just a few minutes. How do I know??
