10-07-2019, 09:57 AM | #21 |
Re: 8ba rod bearing problem
I still have the old bearings separated and marked where they went. If using plastigage what is the desired clearance on rod bearings. Just wanted to check and see how it would turn out. Perfect world would be getting them all the same and that is still option I'm considering. I want to change out front seal to one piece anyway since I'm back inside the engine.
10-07-2019, 09:59 AM | #22 |
Did you have the crank reground at the same machine shop? Even if they just polished it, should have measured/checked ALL the journals . . . so I'm still not letting them off the hook.
10-07-2019, 10:43 AM | #23 |
Wait a minute Gene. Apparently this crank was ground in the distant past when it was common to do this. Either by customer request or the crank guy wanted to save a little wear on his grinding wheels. The engine apparently ran a long time set up this way, so it was not a problem; nothing overlooked.
10-07-2019, 11:17 AM | #24 |
Check it with Plastigage.
10-07-2019, 01:05 PM | #25 |
Ford allowed more clearance on the connecting rod big end bearings than they did the mains. My old Mercury manual lists .0005" to .003" for rod big end bearing clearance and .001" to .0026" for main bearing clearances. Side play on the rods is .006" to .020" for two rods on one crank pin.
10-07-2019, 05:10 PM | #26 |
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
10-07-2019, 06:15 PM | #27 |
When journal sizes are odd, I'd be wanting to make sure there was no runnout anywhere. That would make sure things are still concentric with the center line of the crank. There can be a problem if journals are polished too far. Some folks used to lap the bearings too so you never know what your going to find on these old cranks.
10-07-2019, 08:05 PM | #28 |
I removed the pistons/rods with bearings and have everything ready to go back to the machine shop tomorrow. I'm going to see what he figures out and tells me what the problem is. With my cheap measuring tool it seems to me the rod journal is not round, but more egg shaped. Will let you know what the outcome is.
10-07-2019, 08:56 PM | #29 | |
Eyeballing a "polish" on a crank without measuring it is not something a reputable shop would do. I doubt if the crank even had a bath after the polish. The owner himself picked up on the original patch job (grind) AND egg shaping the journal, who knows. |
10-08-2019, 08:10 PM | #30 |
I think you answered your own question when you measured the journals - two are at .020 and two are at .030 . . . a miss-matched affair. Now, if the journals are in good shape, concentric, no taper, etc -- then I can see no real issue with running .020 bearings on two journals and .030 on the others. Would I do it this way . . . well 'No' - but I'm a perfectionist and I wouldn't want the "next guy" to see an engine I built done in this fashion.
BUT - with all that said, if it is about spending less money - then you can probably put it together with the two different rod-bearing sizes - as long as the resulting clearances are correct. On my Soapbox: What is still of concern is that the machine shop obviously didn't measure the crank . . . so what else didn't they measure? Quality machine work and correct clearances are everything in an engine build . . . . |
10-08-2019, 10:39 PM | #31 | |
10-09-2019, 06:25 AM | #32 |
As another side note, I own both a "in-car" crankshaft grinding machine and boring equipment.
I saw the crank grind done once and the operator was very skilled and efficient. The job was a new Rambler 6 cyl. that was under warranty. As far as I know it survived the warranty period and is still going. Grin. |
10-09-2019, 07:22 AM | #33 | |
10-09-2019, 09:47 AM | #34 |
In car work was usually done on warranty situations where the car was still in near new condition and there was less chance of heavy wear or bending on any of the rotating components. Older components with a lot of wear and tear should get more scrutiny to insure serviceability. A dedicated crank grinding machine is the best way in that situation. Checks are simpler that way and repairs would follow as necessary.
10-09-2019, 06:10 PM | #35 | |
Herm |
10-09-2019, 07:49 PM | #36 |
Hey Herm - just checking . . . RODS, not mains??? I can see a fixture for the mains working, but the rods - that has to be complex! It would have to somehow rotate/articulate with the crankshaft rotation - that seems to be a hard situation to ponder - unless it indexed off the mains in some fashion.
Just curious! |
10-09-2019, 09:44 PM | #37 |
The grinder has a hook opposite the grinding wheel, there was a motor to turn the rear wheel, or fit in the place of the starter to rotate the crankshaft , the grinder moves with the rod journal. It can only make the journal round, but the center of the journal will move if the wear was only on one side
10-09-2019, 10:16 PM | #38 |
I had a crank ground in the car on a Chrysler 383. The wheel on the grinder was quite skall and the starter turned the crank with the lugd removed
10-09-2019, 10:21 PM | #39 | |
Herm. |
10-09-2019, 10:58 PM | #40 | |
Most bearing books have a maximum, and minimum for any given crank. On say a 2" crank, the actual minimum size should be .002 thousandths, and plus, one more .000-50 for a maximum. If you set a 2" crank clearance to .000-50, or even a .001, the crank when hot will expand about .002 thousandths. So what happens is the crank pushes bearing material out of the way until it has the clearance it wants to get enough oil to the bearing to cool the bearing, and stop its expansion, so why waste bearing material, and taking a chance on smearing a bearing. Depending on how fast the car is driven, most of the time will determine what the bearing clearance will be when, Cold, or Hot. Herm. |
