01-29-2019, 02:00 AM | #1 |
cast iron pistons
I just stripped a model A engine,it had cast iron pistons ,
I,m sure Ford would not have used them, it was std bore Lawrie |
01-29-2019, 09:41 AM | #2 |
Re: cast iron pistons
Period aftermarket?
Read an article in Hemmings about cars that were built just before production stopped for WWII coming with cast iron pistons because of aluminum shortages. I think the cars in the article were a Buick and a Plymouth, both 1942 models. |
01-29-2019, 10:23 AM | #3 |
It was most likely used as an industrial engine to run on kerosine or parafine (in England) A special inlet manifold was used where the exaust gas was routed to heat the inlet tract to aid vapourisation.The engine would be started on gasoline and when hot enough switched over to kerosine rather like a Fordson tractor . The cast iron pistons held their heat better to allow combustion of the lower grade fuel . I have had several engines like this out a saw mill etc etc .mostly B engines .
John in cold snow on the way Suffolk County England . |
01-30-2019, 05:01 PM | #4 |
You don't say if your engine is the standard 200 cubic inch Model A engine or if its the "reduced bore" engine used in England because of the arcane tax laws. The engines can be told from the external view. Check out images at https://www.fordbarn.com/forum/showt...ll+bore+engine
If the reduced bore engine, it might have been fitted with Model T pistons. Someone more familiar with the two Model A engine variants AND the Model T engine could verify this thought. Ford didn't waste a thing. And doubtless Ford storage was filled with cast iron Model T pistons. Vince Falter (www.fordgarage.com) has an extensive write-up on engine numbering and the prefixes that might (but not always) accompany a "small bore" (14.9hp) engine. http://www.fordgarage.com/pages/ABenginenumbers.htm Joe K
Shudda kept the horse. Last edited by Joe K; 01-30-2019 at 05:06 PM. |
01-30-2019, 08:44 PM | #5 | |
01-30-2019, 09:14 PM | #6 |
01-30-2019, 09:24 PM | #7 |
Good thought Joe K, but the Model T Pistons wouldn't have fit for several reasons.
The Model T wrist pins are held in with a pinch bolt and are .750 the Model A Pistons Had a circlip and the wrist pins are 1.00. The compression height was also different for the two pistons. I like the idea of the motor being an industrial motor and possibly running on kerosine |
01-31-2019, 12:07 AM | #8 |
Cast iron pistons were produced to fit many makes of cars so they may just be replacements for whatever reason.
01-31-2019, 01:27 AM | #9 |
had another look at them, no circlips holding the pin in,looks like it may have one in the middle of the pin.
they are std bore Lawrie |
01-31-2019, 09:58 AM | #10 | |
Um. The original Model A pistons HAD a single circlip in the middle. Removal is a challenge (especially for 20 something first time disassemblers familiar only with the modern "outside two circlip" style of piston pin.) Disassembly requires a piece of brass drift and a BFH (20 year old) or a minimum 12 ton press, pilot & soft pine as support (now 63 years old and knows a better way - one of life's pleasures.) Assembly is a challenge too requiring a "pilot pin" to spread the single circlip built into original rod-ends (between the small end two bronze bushings) and allowing entrance of the full body pin. Most if not all restorers opt for the greater convenience (and more precise fit) of modern pins with two circlips. I might expect you to find the pistons marked with some standard oversize. If not the only reasonable conclusion I can think would be Ford used "local sources" in your case Australia, in assembling completed engines. Another variation I've seen is the use of "piston skirt expanders" which are metal contraptions inserted into the skirt of the piston and by which the piston body is made larger. These expanders used with oversize rings are held by the pin itself and are unmistakable if seen - and indicate an engine which has been worn to the point of rebuilding. This last just something to look for. Joe K
Shudda kept the horse. Last edited by Joe K; 01-31-2019 at 10:05 AM. |
01-31-2019, 02:07 PM | #11 |
The 3" bore AF engine was never an industrial engine there never was a need as the 3 7/8" bore A engine was far better suited . AA trucks and vans (small and large) were exempt from the "horse power tax" only passenger cars were liable . Ford set 14.9 HP just under the 15 HP which took you up into the next punitive tax level . This tax regime was to curb cheap high quality American imports ,Irskine,Essex Chevrolet Plymouth etc etc .Half the vehicles between the two world wars in the UK and Ireland were Ford T and TT the tax system was designed to protect fully British car makers against Ford competition . The AF engine was a failure as the cars were way underpowered and Fords sales plumetted hence the Ford 8 HP designed by Eugene Gregorie in Detroit.The Dagenham B engine was very tough and not prone to cracks in the valve chamber area as the Detroit engine . The industrial engines had a special preheat manifold,magneto and Woodward governor so were mostly hand crank start I would guess
John in cold Suffolk County England . . John in very cold Suffolk County England Last edited by john charlton; 01-31-2019 at 02:20 PM. |
