04-11-2019, 12:21 AM | #21 |
Re: 1936 3 Window Coupe
Sacramento ford makes great looking modern materials and original harnesses. Probably around $300 for a full kit, harnesses/plural. They will handle 12v later no issue (much thicker wires, really overrated for 12v) if you decide. easy call.
https://www.vintageford.com/sect_sea...ategory=Wiring you are going to need: 1) cab/gauge wire harness feeds to engine. 2) harness off the steering end to lights/cab/etc. 3) rear end harness (stop light/brake switch, lights and gas tank) 4) front light crossover and horn. Pig tails. 5) coil run. (you can make this with the right stock wire and ends) 6) a few clips and bullet connectors http://www.vanpeltsales.com/FH_web/F...ram1936car.jpg Some odds and ends you can make up. It sounds harder then it actually is. Its all color coded wires to stock. If the old harness is there, take pictures or follow when installing. if not... follow schematics and ask questions. As i mentioned you can call them also. Lots of different vendors also. Just my experience. http://www.vanpeltsales.com/FH_web/F...wiring1936.jpg . Never been a fan of modern looking wires in a old ford. Last edited by Tinker; 04-11-2019 at 01:51 AM. |
04-11-2019, 08:15 AM | #22 |
Rhode island wiring has everything you need in original type cloth covering. My 36 3 window was 6V and worked great....
04-11-2019, 08:25 AM | #23 | |
04-11-2019, 09:34 AM | #24 |
“That's a very nice looking 3w coupe!! I would enjoy seeing more pics as you make progress getting it back on the road.”
__________________ I second what JM 35 sedan said! Plus my .02 cents, in a car that original, 6V would definitely add to originality and value. And if you think about it, these cars were daily drivers once, with nothing but 6 volts. |
04-11-2019, 08:31 PM | #25 |
You might consider having turn signals built in to the wiring harness along with a passenger side tail light and perhaps a 3rd stop light. That will make installing turn signals effortless. Today's drivers don't recognize hand signals. I don't see why all the various harnesses can't be combined into one custom made harness. This would also reduce the use of the old fashioned Ford wire connectors. A 6 volt harness will work just fine for 12v. I have 3 old Fords and all are 12v. Makes buying a battery a whole lot easier.
41 woodie https://41fordwoodie.weebly.com/ |
04-12-2019, 03:54 AM | #26 | |
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
04-12-2019, 04:05 AM | #27 |
Your original 6V wiring is of a heavier gauge and is superior to what is required for a 12v system. For mine, 6V or 12V, keep as much of the existing wiring in there as you can.
04-12-2019, 07:31 PM | #28 |
I just received a complete harness for my 36 from Tyree,could nt be happier!I asked for turn signals in the fog lights and a wire for a electric fuel pump,both not factory but neither one was a problem.Tyree has done several harnesses for me and IS a stand up guy that knows his stuff. And I received them both,custom made in a week. ken
04-12-2019, 10:43 PM | #29 |
Thanks everyone! I think I値l stick with 6volt. Anyone have any reasons to not move the battery to under the hood? I was thinking of building a bracket on the passenger side firewall. I致e seen some like that. I plan to have a disconnect on the post, and it seems a little scary to have the battery under the floor.
04-12-2019, 11:12 PM | #30 |
https://fordbarn.com/forum/showthread.php?t=51728
Its a pain to get to the battery with interior. nothing scary about it though.... heat from the engine is not friendly to batteries. you could run a later harness with a solenoid (37-39ish, with cutout, pre voltage regular) and add a button start on the dash. 36s never had a solenoid. floor stomp starter switch. Still using it myself, no issues. if bad wiring or shorts are a concern, you could make a killswitch off the floorswitch lead to cut the battery power to the rest of the car. Last edited by Tinker; 04-12-2019 at 11:59 PM. |
04-13-2019, 04:34 AM | #31 | |
I bought a '35 5W coupe that had the battery mounted to the firewall using a home-made angle iron frame. This restricted access into the engine compartment and was one of the first things I changed back to the original mounting. Now all that remains of that mess are several ugly holes they punched in the firewall. I've kept my 35's 6V and see no reason to change to 8V or 12V. Keeping battery terminals and ground connections clean is important.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 04-13-2019 at 06:45 AM. |
04-13-2019, 09:31 AM | #32 |
You can also buy a "drop down" battery box(Speedway sells them) that mounts to the frame and is placed under the right front fender. Don't damage the firewall with a battery box.
