Old 10-13-2013, 04:36 PM   #1
Mike B
Default Has anyone had success removing the little tranny inspection cover
And freeing up a stuck clutch?
If so, could you give me an idea how you proceeded and with what you used/made?
Thanks
Mike B is offline   Reply With Quote
Old 10-13-2013, 05:01 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Has anyone had success removing the little tranny inspection cover
Unless you suspect something is broken in there, you are better off just freeing up the stuck clutch through tried and true methods. There is at least one method posted in the last several days using jack stands under the rear axle and shifting the trans into second gear. Start the motor and rev it a bit then hit the clutch & brake simultaneously. Just be certain the car and stands are on firm footing and the rear tires are clear to spin before the attempt.
Old 10-13-2013, 05:16 PM   #3
Mike B
That's worth a shot..I'd tried (foot in clutch/3rd gear) bumping the starter without luck.
Thanks, will give it a try right now!
Old 10-13-2013, 05:20 PM   #4
Mike B
Well dang...that took all of about 2 tries!!!
Sweet!
Thanks so much!
Edit:
I already had it on stands, that's why it went so quick.
Thread Tools
Display Modes
