10-13-2013, 04:08 PM | #1 |
Float level
My 1939 pickup carb 91 - 99 was flooding. I removed the top of the carb and checked the float level. for the 46 to 48 carbs the float should be set at 1.322 to 1.353" . My older Motors book says the gas level in the bowl should be 9/16" below the top edge of the bowl. My gas level was high and the float was at the right level by the standards that I had, so I set the float to be 1/8" lower in the bowl. It seems to run properly and doesn't flood. I would prefer to know what the proper level for the 91 - 99 carb should be and if I will have a problem with the float level set lower that specified.
By the way I took it for a test drive and it ran badly, like I was running out of gas. I stopped for gas and put 15.5 gals in my 16 gal tank and did not allow it to run over. Thanks for any help coming my way. Bill Last edited by V12Bill; 10-13-2013 at 04:10 PM. Reason: Addition |
10-13-2013, 06:40 PM | #2 |
Re: Float level
I set all my 94 type carbs at 1 7/16" 1.368 / nobodys complained but 1 guy and he wanted to cruise down the hiway at 75-80 mph. He raised it a little ??? ken ct. This is dry measurement with top inverted and in closed position Steel inlet needle not a rubber tipped one. ken ct. OMO
10-13-2013, 07:13 PM | #3 |
Re: Float level
Bill |
