Old 10-08-2013, 09:19 AM   #1
Birfdaycake
Default New to me Very good condition 1936 ford pickup
We just got a garage kept since 1936 ford pickup. We started it drove it everything was good. Everything is stock original. It's our first old ford. I was wondering how many are in gret shape and all original still. Also. I was planning on pulling the gas tank to check out the inside condition. Does the be need to pulled to do this. Any other info or things I should look at would be greatly appreciated. Also the original wood panel floor plates that drop in need to be replaced. We want to do wood again. Is there a kit for this or something else you folks suggest
Birfdaycake is offline   Reply With Quote
Old 10-08-2013, 09:45 AM   #2
bk53
Default Re: New to me Very good condition 1936 ford pickup
Nice score! enjoy the learning process.
bk53 is offline   Reply With Quote
Old 10-08-2013, 10:10 AM   #3
Lawson Cox
Lawson Cox's Avatar
The truck looks nice for a driver. These old trucks are a lot of fun, and are not very common.
"EVERYTHING" is not "STOCK ORIGINAL" First thing to jump out at me is the paint job. Belt molding around the cab is not body color as original. What wood do you plan on replacing? If it has a wooden floorboard in the bed, it is not original. Original bed floor is covered with steel. What about more pictures. Roy Nacewicz makes the wood for this truck if you need new wood.
I am working on 35-36 pickup book, but it is still in its rough form. Don't know when book will be published. If I can help with anything strictly pickup, let me know.
Lawson
Old 10-08-2013, 10:17 AM   #4
Birfdaycake
The bed has the original steel. Mechanically other than that paint it's original. I have to replace the floor boards in the cab.
Old 10-08-2013, 10:19 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
Lawson, I hope you and Jerry keep plugging away on that book and get it done. I would love to see that published and buy a couple copies.
Thank you!
John
Old 10-08-2013, 10:27 AM   #6
FHFD
FHFD's Avatar
Nice p/u..enjoy!
"Get your facts first..then you can distort them as you please"
FHFD is offline   Reply With Quote
Old 10-08-2013, 10:46 AM   #7
Vic Piano
Vic Piano's Avatar
That is a sharp lookin' truck... Have fun with it.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 10-08-2013, 10:47 AM   #8
Scott H in Wheaton
Scott H in Wheaton's Avatar
Very nice, would love to see more photos
Scott H in Wheaton is offline   Reply With Quote
Old 10-08-2013, 10:57 AM   #9
JM 35 Sedan
Yes, it looks like you found a very nice '36 pickup. As someone else mentioned, it would be great to see more pictures of the exterior, interior and engine compartment. Get it running good, mechanically safe, and enjoy the ride!
I am wondering where you are located (approximately) and if you are a member of the Early Ford V-8 Club? It would be great to see that PU at one of the scheduled 2014 meets.
John
Old 10-08-2013, 11:44 AM   #10
Birfdaycake
I'm locate in Middletown Delaware.
Old 10-08-2013, 11:55 AM   #11
Lawson Cox
Lawson Cox's Avatar
Thank you!
We are still working on it but not with fire we had in our bellies before the EFV8CA threw us under the bus.
Old 10-08-2013, 12:07 PM   #12
Bob G/Spanaway
Bob G/Spanaway's Avatar
I think it's pretty rare to see one that has never been messed with.
Very nice!
Bob G/Spanaway is offline   Reply With Quote
Old 10-08-2013, 12:12 PM   #13
banjoQ
banjoQ's Avatar
Sir- you are a lucky man! What a great truck. You are right to want to get a look in the tank. You will have to drop it and remove the sender and the filler tube to get a good look. Not knowing the history of the truck but it could go either way. Any rust or scale and I would suggest replacement. They don't cost that much and it would save you time and frustration. You must know by now if the brakes are serviceable, keep a close eye on them. If the truck has sat for a long time they might deteriorate fast with use. The floorboard can be made easily using the old one as a template. I tend to look at these vehicles as more of an example of American Folk Art than shrines to Henry Ford. So changes in the mechanics or appearance are further examples of the many hands that have worked on the vehicles over the last 77 years. Have fun with your truck and be sure to share with your family and friends. Good luck.
banjoQ is offline   Reply With Quote
Old 10-08-2013, 12:21 PM   #14
Birfdaycake
Do any of you guys know a round about number of what one like this might be worth. Besides that brown strip and the needing of new cab floor boards it's is all original and has Ben kept in a garage. By the way I'm only 28 so I have limited knowledge of these old fords. So any help is very much appreciated
Old 10-08-2013, 04:10 PM   #15
Fibber Mcgee
Fibber Mcgee's Avatar
I don't know what its worth but I do know the closer to original you keep it the more it will be worth. DON'T CUSTOMIZE IT.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 10-09-2013, 09:50 AM   #16
TJ
TJ's Avatar
If the wood floor boards need replacing then you should check under the cab to see if the wood supports between the frame and the cab also need replacing.
Old 10-09-2013, 10:40 AM   #17
mhsprecher
mhsprecher's Avatar
Very cool. You are a lucky guy!
mhsprecher is offline   Reply With Quote
Old 10-09-2013, 12:04 PM   #18
Gumpy
Gumpy's Avatar
nice lookin truck, build it the way you want it, and have some fun!
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is online now   Reply With Quote
Old 10-10-2013, 06:36 AM   #19
JLB3
The good think about original un-modified old fords, is the fact that you can buy replacement parts from places like Macs and Bob Drake, Dick Spadaro and others. It's not cheap, but the parts would be drop in replacements (Bed wood, cab support wood, floorboards etc...)
I jump on the opportunity to buy an un-modified old pickup like yours.
JLB3 is offline   Reply With Quote
Old 10-10-2013, 06:50 AM   #20
31chevy
31chevy's Avatar
very nice find. Enjoy!!!
Gary.
31chevy is offline   Reply With Quote
Thread Tools
Display Modes
