Old 01-19-2018, 12:12 PM   #1
wingski
wingski's Avatar
Default cam holder tool
Here are a couple of pictures of the cam holder tool to help with timing that I just made. I think it came out pretty cool.
Mike
wingski is offline   Reply With Quote
Old 01-19-2018, 12:18 PM   #2
3.6rs
3.6rs's Avatar
Default Re: cam holder tool
Don't they sell that tool for little money ?
3.6rs is offline   Reply With Quote
Old 01-19-2018, 12:22 PM   #3
2manycars
2manycars's Avatar
Nurex makes such a tool for about $10.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 01-19-2018, 12:25 PM   #4
3.6rs
3.6rs's Avatar
That's it.
Old 01-19-2018, 01:48 PM   #5
wingski
wingski's Avatar
Guys, I live in the middle of nowhere. I have a napa store about 5 miles away, but everything else is at least thirty miles away. Besides that, the idea of buying one when the tool I made was simple and fun to do doesn’t make sense to me. Buying online takes time to recieve the item and is somewhat iffy. Also, buying online can take as much as one to two weeks to receive the item where I live.
Mike
Old 01-19-2018, 02:02 PM   #6
SAJ
SAJ's Avatar
Thats a very nice job Wingski. And I would far rather enjoy the pleasure of a good home made tool than a bought one personally, too.
But I understand others may consider it a waste of time, if a similar tool can be bought cheaply.
However wrestling with metals is what I and many others enjoy as just one aspect of old car restoring. There is a certain satisfaction for us in holding and using a nice tool, and this feeling is heightened when that tool was crafted personally or by a friend.
Keep up the good work.
SAJ in NZ
SAJ is offline   Reply With Quote
Old 01-19-2018, 02:04 PM   #7
JDupuis
JDupuis's Avatar
Gees Mike, that's it, you're gonna have to drop everything and move closer to me. I have dealers real close to where I live. Plus lots of tools.
Think about it! Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 01-19-2018, 02:13 PM   #8
3.6rs
3.6rs's Avatar
Originally Posted by wingski View Post
Guys, I live in the middle of nowhere. ... Also, buying online can take as much as one to two weeks to receive the item where I live.
Mike
...two weeks to receive the item when buying on internet ??
I think you don't live "in the middle of nowhere", you must be living on the moon.
Old 01-19-2018, 02:37 PM   #9
midgetracer
midgetracer's Avatar
The nice thing about the NuRex tool is that it set the timing for you. Very easy to use.
midgetracer is offline   Reply With Quote
Old 01-19-2018, 02:55 PM   #10
shookie
The last time that I checked the cam wrench sold for ONLY 1.25 and the Nu-Rex wrench ( pictured ) is for timing the engine is sold for 10.50 .......
shookie is offline   Reply With Quote
Old 01-19-2018, 03:16 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
I used old rotor with hole in center--- free and easy---
Old 01-19-2018, 03:43 PM   #12
hardtimes
hardtimes's Avatar
Good for you, nice job !
Anytime that a guy can help himself and make what is needed, I applaud that effort !
Old 01-20-2018, 01:41 AM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Nice job. I also like homemade tools. After drilling the hole, how did you make the lug for the notch?
Old 01-20-2018, 08:36 AM   #14
Ed Northrop
Ed Northrop's Avatar
Very nice looks like you are a expert with a die grinder
Ed Northrop is offline   Reply With Quote
Old 01-20-2018, 09:02 AM   #15
jhowes
I have the same question that Tom has about the lug. Jack
jhowes is offline   Reply With Quote
Old 01-20-2018, 10:16 AM   #16
wingski
wingski's Avatar
Thanks, I appreciate you guys who realize that it is fun to make something by yourself and have the only one that is exactly like it in the world.
The aluminum I used is 3/8” thick, and I cut it from a big piece using an angle grinder. Then, I used my table grinder to smooth all the edges. I put the tool in a vice and drilled the hole so the cam would fit in it fairly tight but would not bind. Then, I took a small thin tipped punch that had been sharpened to a point and punched two holes on each side of where the slot was on the cam. I did this on both sides of the tool. The punch actually stuck in the aluminum and penetrated almost 1/8”. After that, I used a blunt chisel to flatten that small piece and force it into the openng. I used a small trianglular file to square off the edges on the protrusion and a small flat file to square it off. I was able to get the actual hole just the right size by using a small round file.
By the way, all those files had been my Dad’s, and I thought a lot about him as I used them.
I am very proud of what I made as you can tell, and it is worth a lot more to me than $10.
Thanks again for your interest,
Mike
Old 01-20-2018, 10:16 AM   #17
chap52
chap52's Avatar
I think just making some of this stuff is therapeutic at the very least. The inconvenience of living in the Cave Junction area is well worth the commute. I lived a few places in Oregon that were well worth the 40 minute drive to civilization.
Good job on your rural shop tool.
chap52 is online now   Reply With Quote
