Old 09-12-2019, 01:47 PM   #1
Ricosan
Ricosan's Avatar
Default 6V generator
I just bought a “rebuilt “ 6V generator from a fellow on EBay. It looks real good but it has a loud squeal when turned by hand. Should I send this generator back?
Richard
Ricosan is offline   Reply With Quote
Old 09-12-2019, 01:52 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: 6V generator
Maybe a brush "cocked" during shipping??
Paul in CT
Old 09-12-2019, 01:54 PM   #3
petehoovie
petehoovie's Avatar
Richard
If it is truly rebuilt it will have new brushes. Many times the new brushes will squeal....
"Silver rings, your butt! Them's washers! Damn!"
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 09-12-2019, 03:22 PM   #4
Ricosan
Ricosan's Avatar
I don’t want to send this generator back if there is a chance that it’s just a matter of running it for a while. Tomorrow I’ll install it and run it for a bit.
Richard
Old 09-12-2019, 03:59 PM   #5
KGS
KGS's Avatar
Richard
I would contact the seller first and discuss your concerns. I don't know the terms of your sale but most sellers won't take back an electrical item if it has been used.
KGS is offline   Reply With Quote
Old 09-12-2019, 07:24 PM   #6
flatford8
flatford8's Avatar
X2 on this advice...let them know you think there might be a problem and ask if you can return it if you end up being right.....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 09-12-2019, 07:48 PM   #7
Ricosan
Ricosan's Avatar
Thanks guys, good advice. I’ll get in touch he seller before I install.
Richard
Old 09-12-2019, 09:32 PM   #8
Scotty's 52 F3
Scotty's 52 F3's Avatar
When I rebuilt my generator the new brushes on a fresh commutator squealed like you describe. They will wear in as mentioned.
Please let us know how it goes so this can help others down the road instead of being a dead end thread.
Scotty's 52 F3 is offline   Reply With Quote
Old 09-12-2019, 09:35 PM   #9
Tinker
Tinker's Avatar
I'd make a complaint to the company even if it turns out well just for records. You can always say your fine publicly.
Old 09-12-2019, 09:49 PM   #10
petehoovie
petehoovie's Avatar
If you've got some dielectric silicone spray or contact cleaner on hand, spray it on the commutator where the brushes mate and I'll bet the squeal goes away....
Old 09-13-2019, 03:44 AM   #11
koates
Sorry but I don't recommend spraying anything on the commutator or brushes at all. Take the generator to your local auto electrical shop and have him run it up on his test bench. The only thing to do on the commutator is run some fine sandpaper around it. Don't use emery paper. Regards, Kevin.
koates is offline   Reply With Quote
Old 09-13-2019, 06:40 AM   #12
Terry,OH
Terry,OH's Avatar
Did you add oil to the rear bushing through the oil cup? What year is the generator?
Old 09-13-2019, 08:02 AM   #13
Kurt in NJ
Kurt in NJ's Avatar
many times brushes will squeak when the generator is turned backwards
Old 09-13-2019, 08:10 AM   #14
Bill OH
I had the same problem with squeaky generator brushes on a flathead when I was 16 and my grandfather had me put just a drop of kerosene on the commutator and no problems after that application.
Bill OH is offline   Reply With Quote
Old 09-13-2019, 01:41 PM   #15
Ricosan
Ricosan's Avatar
Hey Guys,
Thanks for all the comments and suggestions. I’ve just finished installing the generator. Too hot for a long drive this afternoon so I plan to take it out in the morning for a 10 or 15 mile drive to see if I can get the brushes to settle in.
Richard
Old 09-14-2019, 12:26 PM   #16
Ricosan
Ricosan's Avatar
Took my car for a drive this morning. Squeal is still there but the engine makes so much noise I can hardly hear it. Problem is that it isn’t charging. My original generator had 2 wires coming from the hole on topand this one has only a single post. I think I hooked it up correctly. Here is what I did. I made a short piece of wire to connect the “ARM” side of the cutout to the post on the generator and connected the battery wire to the “BAT” side.
No weird noises or any smoke. Does it sound like a bad cutout?
Richard
File Type: jpg 430B0BFA-6C5E-442F-B48D-1D8B4545B2AB.jpg (39.3 KB, 58 views)
Old 09-14-2019, 01:09 PM   #17
Bob C
Looks like you are missing the insulator on the cutout cover.
Bob
Old 09-14-2019, 01:42 PM   #18
petehoovie
petehoovie's Avatar
Originally Posted by bob c View Post
looks like you are missing the insulator on the cutout cover.
Bob
yup!
Old 09-14-2019, 03:29 PM   #19
Ricosan
Ricosan's Avatar
Thanks guys, I found the old insulator stuck to the end of the wire on my old generator!
I installed it and I started it in the garage It appears to be working. I will take it for a drive tomorrow to see if is functioning properly.
Richard
Old 09-15-2019, 09:24 AM   #20
Ricosan
Ricosan's Avatar
Started my car this morning to take it out for a test of the generator. It started easily but as soon as I massaged the accelerator to keep it running, I heard a loud noise. As I raise the RPMs, this noise intermittently kicks in and out. Had no noise on my drive yesterday. The only thing different is the addition of the insulator washer.
Richard
