Old 12-05-2018, 07:13 PM   #1
Beater
Beater's Avatar
Default aftermarket oil filter kit
so after having the pan off for the first time ever, and seeing all the crap in the bottom, I'm thinking about adding one of those oil filter kits my question is, are they kinda all the same? some better than others??
Beater is offline   Reply With Quote
Old 12-06-2018, 06:54 AM   #2
brokenspoke
Default Re: aftermarket oil filter kit
The search function is your friend
https://www.fordbarn.com/forum/showt...ght=oil+filter
https://www.fordbarn.com/forum/showt...ver+oil+filter
brokenspoke is offline   Reply With Quote
Old 12-06-2018, 07:10 AM   #3
brokenspoke
This is how I did mine
https://www.fordbarn.com/forum/attac...2&d=1529580796
Old 12-06-2018, 09:44 AM   #4
Jim Baskin III Pa.
Jim Baskin III Pa.'s Avatar
This is what I have used for the last 10yrs.
https://www.snydersantiqueauto.com/oil-filter-kit
Jim Baskin III Pa. is offline   Reply With Quote
Old 12-06-2018, 10:01 AM   #5
Dave in MN
Dave in MN's Avatar
I am with Jim. I have had one of these since 2000 on my Phaeton. 90,000+ miles and the engine is still going strong.
Good Day!
Dave in MN is offline   Reply With Quote
Old 12-06-2018, 10:39 AM   #6
katy
katy's Avatar
I used one of those but the copper tube didn't fit like it was supposed to, I fabricated a tube that would fit using the supplied fittings and the filter seems to work fine. Next time I do an oil & filter change I'm gonna paint the filter flat black before I install it.
Old 12-06-2018, 01:12 PM   #7
amodel25
amodel25's Avatar
Ford engine green looks pretty good too.
amodel25 is offline   Reply With Quote
Old 12-06-2018, 01:28 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Beater, you've been thinkin' a long time. Your quote from over 2 years ago...
I'm thinking I will add one to mine aswell
in this thread.
The WIX 51515 filter is black, just peal the sticker off.
Old 12-06-2018, 11:09 PM   #9
Beater
Beater's Avatar
well I don't wana just jump on the band wagon, right away Y-Blockhead
Old 12-07-2018, 03:31 PM   #10
Synchro909
Synchro909's Avatar
I have used the filter that screws on to the valve cover on 3 of my cars but I have a spare engine on a stand on which the filter is mounhted non a bracket beside the motor. Oil is taken from the side of the block just above the oil pump and returned to the timing gear cover. Not sure I like that one as much and I don't know what filter should be on it. For simplicity, it would be good if I were able to use the same one as the others. (Z9)
Old 12-08-2018, 09:54 AM   #11
katy
katy's Avatar
It depends on the base that was used, a lot use the same filter as you're using on the other A's, Fram PH8A, WIX51515 or equivalent.
Try one of the filters from your other cars, it might just fit.
Old 12-08-2018, 05:18 PM   #12
Synchro909
Synchro909's Avatar
The Z9 fits the base OK but there is more to selectiong the right filter than that. For simplicity, I think I'll run with the Z9. I'll be able to do a bulk buy deal, too!
Old 12-09-2018, 10:20 AM   #13
katy
katy's Avatar
Here's an interesting old thread about oil filter kits, particularly see post #8
https://www.fordbarn.com/forum/showt...ote+filter+kit
Old 12-09-2018, 04:24 PM   #14
Synchro909
Synchro909's Avatar
Apart from the minor deatil as to where the filter is mounted, that sounds like my setup. His observations are comforting. I will continue using it and drive on. Thanks, Katy.
