Old 04-10-2018, 09:15 AM   #1
Nelson C
Default 1931 S/W Fordor Sedan Dome Light Wiring
Our 1931 S/W Fordor has a wood block above the rear window for a Dome Light. (The car was disassembled by the previous owner.) Please help with the following:
1) Does the Repro Dome Light get mounted flush to the wood block with screws from the inside of the light?
2) Does an On/Off Switch get mounted to the passenger side door post?
3) There's a single wire (green) coming out of the reproduction Dome Light. How is the Dome Light wired and grounded?
Thanks very much for your help.
Nelson C is offline   Reply With Quote
Old 04-10-2018, 09:39 AM   #2
160B
160B's Avatar
Default Re: 1931 S/W Fordor Sedan Dome Light Wiring
Ford Service Bulletin page 468 June 1930
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 04-10-2018, 11:57 AM   #3
burner31
burner31's Avatar
Does your dome light mounting wood look anything like this?
I had to make my own because the one I found at an old junkyard did not fit right,
Keith
Shawnee OK
'31 SW 160-B
Old 04-10-2018, 07:05 PM   #4
Don Turley
Don Turley's Avatar
There is not a correct reproduction oval dome lamp made for the Model A Ford. The only reproduction dome lamps that I am aware of are the round ones for Coupe and Tudors. They mount more towards the center of the headliner. The oval dome lamps in the four door sedans and Victorias mounts above the rear window.
Don Turley is offline   Reply With Quote
Old 04-15-2018, 05:04 PM   #5
jimcarl
jimcarl's Avatar
Here's what it looks like on my 31 S/W.
jimcarl is offline   Reply With Quote
Old 04-18-2018, 04:22 PM   #6
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
I would obtain a copy of the RG/JS and many of your questions will be asked
Mark Maron
Ill., Region MARC & MAFCA
27A's, MARC JSC Member
MARC Dearborn 2019 Meet Chairman
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
msmaron is offline   Reply With Quote
Old 04-18-2018, 11:17 PM   #7
160B
160B's Avatar
Your link
results in the below message
"Sorry, this content isn't available right now
The link you followed may have expired, or the page may only be visible to an audience you're not in.
Go back to the previous page Go to News Feed Visit our Help Center"
I am a member of MARC can I join the closed group?
Old 04-19-2018, 07:30 AM   #8
jwilliams81
jwilliams81's Avatar
Originally Posted by 160B View Post
Your link
Correct link:
https://www.facebook.com/groups/MARCFordGroup/
1931 Murray Town Sedan. Black body with Apple Green pin stripe. Cincinnati, OH
jwilliams81 is offline   Reply With Quote
Old 04-19-2018, 09:18 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Make sure that the dome light body is well grounded or the light will not work. In my Model "A," I soldered a second wire to the metal body of the light and ran it to a screw in the car body that I tested to have good ground continuity.
I also converted the dome light to LEDs.
Bob Bidonde
Old 04-23-2018, 10:23 PM   #10
jimcarl
jimcarl's Avatar
These LEDs plug right into the standard socket. I also have them in my taillights.
https://parts.modelastore.com/show_Product.asp?ID=18460
Old 04-26-2018, 12:46 PM   #11
burner31
burner31's Avatar
Ordered three of these lights, two for the cowl lights and one for the dome, will post pics of the before and after when they get here.
Was never real happy with the cowl light brightness, but the dome light seems plenty bright with the 6V bulb, but going to try it anyways.
Keith
Shawnee OK
'31 SW 160-B
