Old 01-07-2018, 06:50 PM   #1
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Rear main oil return tube
I broke one off , flipping the engine around while installing pistons. It was tacked in place. I was able to get the broken threaded piece out easily. I went to see if I had some 5/16” ones on old caps. Found two with a ball check valve. Anyone know the “theory “ behind this??
File Type: jpg 38498F05-4190-4BB9-8B58-9FA99E061DFC.jpg (50.7 KB, 80 views)
File Type: jpg 889F4E2A-A597-4C02-8960-03A4DF0B05DE.jpg (91.4 KB, 86 views)
Old 01-07-2018, 06:53 PM   #2
George Miller
George Miller's Avatar
Default Re: Rear main oil return tube
They were for grain trucks. They use to pick the front of the trucks up in the air, to dump the grain. The ball kept the oil from running out of the engine.
George Miller is offline   Reply With Quote
Old 01-07-2018, 07:31 PM   #3
Kohnke Rebabbitting
Do not use 5/16 ones. If that is the size, bore to accept the newer 3/8's.
Look for other posts on the barn on how to do the complete job.
I have to leave right now.
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 01-07-2018, 11:06 PM   #4
Chuck Sea/Tac
Page 306 in the service bulletins. Thanks
Old 01-09-2018, 10:43 AM   #5
Dave in MN
Dave in MN's Avatar
Herm.
I agree with Herm: 5/16" is limited to the amount of oil flow it can handle. They have caused rear main leaks for me. I change all rear caps over to 3/8".
Good Day!
www.durableperformance.net
Dave in MN is offline   Reply With Quote
Old 01-09-2018, 12:11 PM   #6
George Miller
Good Day!
I also change them to 3/8 Ford changed them to 3/8 because 5/16 is to small.
Old 01-09-2018, 03:48 PM   #7
Synchro909
Synchro909's Avatar
3/8" gives 20% more flow than 5/16", FWIW.
Old 01-09-2018, 04:02 PM   #8
hardtimes
hardtimes's Avatar
Hey George,
I realize that the tube thread (3/8) is peculiar. Other than not having right die, is there anything that you can think of , why a guy cannot make one ?
I just got a B block without the drain tube....and as things go last few years, can not locate much when needed/wanted in stuff pile !
Old 01-09-2018, 07:56 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Actually about 50% more flow, since you square the radius and multiply by pi to find the area.
Old 01-09-2018, 08:15 PM   #10
1955cj5
1955cj5's Avatar
That is interesting.....I'd like to see a picture!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 01-09-2018, 08:28 PM   #11
Tom Wesenberg
They still dump grain that way for the trucks without a lift.
Shorpy has lots of old pictures, or Google might turn up a picture.
Google "tipping truck to dump grain"
Old 01-09-2018, 09:18 PM   #12
George Miller
Originally Posted by hardtimes View Post
Hey George,
You might use a pipe thread. It will work fine.
Old 01-09-2018, 10:11 PM   #13
hardtimes
hardtimes's Avatar
Ok, thanks !
Hadn't thought of that .
I guess copper pipe would work, instead of steel as used by Ford.
Old 01-09-2018, 11:31 PM   #14
Synchro909
Synchro909's Avatar
Old 01-10-2018, 12:39 PM   #15
Purdy Swoft
Purdy Swoft's Avatar
Here is what I do ...There is more to it than 3/8 . Its the number of threads per inch if you need to fit a replacement drain tube to a 3/8 hole . I use a 3/8 by 32 threads per inch tap . This works with the drain tube threads that most model A parts venders handle. This is probably an uncommon tap . I got mine from Kodiak cutting tools www.amazon.com or www.kodiakcuttingtools.com . Brattons lists the drain tubes on page 44 and yes I have performed this proceduer many times .
Old 01-10-2018, 02:19 PM   #16
Dave in MN
Dave in MN's Avatar
Purdy is probably correct about the 3/8 by 32 but I have found George Miller's suggestion works for me.
I use a 1/8" pipe thread tap and it always works. I spot weld the 3/8"steel pipe to the cap with stainless wire and find it holds well. I also drill out the oil passage in the cap to 3/8" when doing this conversion. Be careful, go slow, when the tip of the drill bit nears the back of the cap as the bit can bind in the grooves.
The tapped hole is not 90 degrees to the parting line of the cap. I built a jig from a cut-off of 10" structural "C" channel to position the cap to achieve the correct angle. If you place a 3/16" spacer under the front edge of cap with the rear of the cap on the bed of your drill press, the angle of the pipe will be correct. I use a 5/16" drill to prepare the cap for the 1/8" pipe thread tap and while the cap is in the jig, I use the drill press to start the tap to achieve alignment.
Photos below:
This jig is used for multiple functions...so ignore the other holes and knotches.
The bottom row of photos shows the procedure to enlarge the oil passage.
Remove galley plug with a punch...Drill passage with a 3/8" bit....continue drilling but don't drill out the back side. The last photo shows where to stop.
Good Day!
File Type: jpg 20180112_204415_1515811790348_resized-2.jpg (34.2 KB, 49 views)
File Type: jpg 20180112_203937_1515811794255_resized-2.jpg (45.6 KB, 49 views)
File Type: jpg 20180112_204138_1515811793109_resized-2.jpg (50.8 KB, 53 views)
File Type: jpg 20180112_204255_1515811791996_resized-2.jpg (41.0 KB, 52 views)
Old 01-10-2018, 03:07 PM   #17
Beater
Beater's Avatar
very interesting. I have to pull the pan on my speedster as the oil plug is loose and just spins. while its out I think ill drop the rear main and do this upgrade
Beater is offline   Reply With Quote
Old 01-10-2018, 03:16 PM   #18
George Miller
The tapped hole is not 90 degrees to the parting line of the cap. I built a jig to position the cap to achieve the correct angle. If you place a 1/8" spacer under the front edge of cap with the rear of the cap on the bed of your drill press, the angle of the pipe will be correct. I have a photo of my jig I will add to the post later if I can find it...or I'll take another photo.
Good Day!
Dave is right on. I also drill the oil passage also very important. You never know what you are going to find in that hole. Plus it fixes the tube from blocking the oil flow through the cap, if it is screwed in to far.
Old 01-11-2018, 09:51 AM   #19
katy
katy's Avatar
I'd stay away from copper on this application. It might "work harden" from vibration and then crack and fall off. Why take a chance? Use steel and be done w/it.
Old 01-11-2018, 01:18 PM   #20
Kohnke Rebabbitting
The tapped hole is not 90 degrees to the parting line of the cap. I built a jig to position the cap to achieve the correct angle. If you place a 3/16" spacer under the front edge of cap with the rear of the cap on the bed of your drill press, the angle of the pipe will be correct. I use a 5/16" drill to prepare the cap for the 1/8" pipe thread tap and while the cap is in the jig, I use the drill press to start the tap to achieve alignment.
Photos below:
Good Day!
Good Jig, Dave.
Herm.
