12-12-2016, 06:36 PM | #281 |
Re: Truck based woody
That looks awesome!!!..... Can't wait to go for a ride!!..... Mark
12-12-2016, 09:52 PM | #282 |
I have seen quite a few photos by now of 'phantoms' or 'one offs' and there are a few where the belt line or the tops of the doors don't line up in a 'fair curve'. I have striven to keep the lines in fair curves as I go, sometimes needing to tear pieces out and re-do the joints after the fact because I wasn't happy with the line up. About 1/2 hour ago I returned form a buddy's shop where we pulled out a bunch of ash veneers he bought for a project 25 years ago. These are sequential flitches so the pattern can be laid out on the woodie in the manner that the tree grew. I have a veneer press and plan to adhere these veneers to the marine plywood panels that are fitted to the body. The panels are all still removable from the inside.
12-12-2016, 11:42 PM | #283 | |
I will be pulling a trailer back to Hansville from SoCal after Easter and should have some room. If you can wait until Spring I can bring it up when we come back. I'd like to make a trip over to Orcas and have a look at your project. Les Williams |
12-13-2016, 10:53 AM | #284 | |
Tim
12-13-2016, 11:19 AM | #285 |
Either way that works best. I don't suppose we have to decide right away, so we can call it when it gets closer. Very kind of you to offer me that tank. Anyone have a pic in or out of the truck so I can see how it mounts? This could help for when I rout other wiring or exhaust etc if that comes first.
12-13-2016, 11:56 AM | #286 |
12-13-2016, 01:31 PM | #287 |
GB, Woodie is looking great! Looks like it rolled of the line!
Keep V-8ing and 4-banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
12-13-2016, 04:29 PM | #288 |
GB.... pics of the tank and where the filler comes out of the bed......Mark
12-13-2016, 04:32 PM | #289 |
The pictures are sideways...... like all my pics post!!... if you need measurements let me know.... Mark
12-13-2016, 07:49 PM | #290 | |
I'll shoot some photos tomorrow of the tank. Les has PM'd me and we're working out the details for the relay north in April if that works for you. Tim
12-13-2016, 08:59 PM | #291 |
It MORE than works! Thanks so much!
12-14-2016, 07:56 PM | #292 |
Photos of the '39 p/u tank.
12-18-2016, 09:31 PM | #293 |
It will work great! Been doing some measuring and looks good. I found a bit of time this afternoon to make a mock-up of a rear barn door. This has been a real big problem because of my lack of a real plan on this build. I like to think that nothing is insurmountable, and I still believe that. Between the heavy rear pillars, which are about 3" x 5" I installed a horizontal cross member which I felt would be notched for bumper brackets at a later date. When I got around to planning rear doors or a tailgate and hatch I found that the layout was not compatible with what I had built. On a ford woodie, the tailgate incorporates that horizontal cross member, and it is hinged in such a way as to fold into that space. My design lead to a very strong rear section, but did not allow for a bottom rail on the doors or tailgate. Now my plan is to saw out the 1 x 6 maple cross member and save the bottom 2" or replace the 1 x 6 with a 1 x 2 which is backed up underneath with a strong maple or maybe steel structure to give the rear some extra rigidity. Either way, this mockup is where I am now. I am no stranger to re-work and I will start out with the chainsaw and end up with a router pattern using a top bearing bit. I have all the maple on hand for the rear doors and hope to start this phase after the holidays.
12-18-2016, 10:40 PM | #294 |
Before you cut that lower cross brace there might be another way to deal with it. The attached photos show a late model (48-53) F1 bumper and brackets that I used on the tonner along with a step/toeplate that was fabricated to fill in the gap between the bed and frame. The mounting holes on the (48-53) brackets exactly matched holes in the 40 frame-no drilling and were fabricated with a "kick down" so that the top of the bumper was almost on the same plain as the lower edge of the fender. Judging by your photo it looks like the top of the bumper would be right at or very close to the bottom of that cross brace. The plain iron bumper and brackets came from C&G Ford. http://cgfordparts.com/
12-19-2016, 12:35 AM | #295 | |
12-19-2016, 04:19 AM | #296 |
Hi GB. The truck is taking shape nicely. I have looked at the pics and think the heavy crossmember needs to be moved inwards, behind the doors. then a thinner sill piece could be used below the doors. I looked at the English Morris travellers that have wooden construction and barn doors. they have a sheet metal sill below the doors and a deep step up inside the doors.
The deep cross piece (in your case) is very necessary to give strength to the rear structure. I don't know about the bumper, but in my mind it wants to be as simple as possible (if you have one at all). Type in "Morris traveller rear" in google images and you will see what i was looking at. Here's one showing the bumper brackets poking through the rear panel. Not saying you should do it like that, just showing that the strength can be behind the doors and just a cosmetic sill panel below. Mart. |
12-19-2016, 11:34 AM | #297 |
I like that. Structural deep cross member, but moved forward in front of the doors. Looks like I'll be busting out the chain saw soon. Behind the 1" maple is a 2" douglas fir piece that mimics it, and the two are bonded with the 3m 5200 marine adhesive. I would like to have a rear bumper hung on some expaver drop down brackets as I've been known to bump things on occasion while backing up.
12-19-2016, 09:18 PM | #298 |
Oh the humanity..... Rest assured it will look good as new, but that will be after the holidays. New cross member, probably steel with a maple board in front coming soon.
12-20-2016, 10:28 AM | #299 |
Your shop looks like mine......I need a lot of stuff...to pile my other stuff on top of....Mark
12-20-2016, 12:53 PM | #300 |
GB,
Like flatford8, I like to see other workshops too. It is interesting what others do and have in the background. In your post #298, in the third photo, under the rear of the truck, on the right hand side, there is a tool tote like the ones we used in cable splicing for the telephone co here. Where you a telco cable splicer? ...Terry |
