Re: Tranny info and test?
That 32 transmission has a relatively low V8 number too. If you have a 32 vehicle, the numbers likely won't match unless it came from that vehicle. The trans cases were stamped at powerplant assembly then the frame was stamped when the engine/trans assembly was installed.
